Edelbrock Air Gap (7501) with Edelbrock 1400 Carb - Team Camaro Tech
post #1 of 2 (permalink) Old May 30th, 14, 09:18 AM Thread Starter
Jeremy
Hi All,
Just wondering if anyone has experience with this setup? My old C3BX manifold has a leak where someone tapped a hole to far for the power steering pump so it's time to replace it. I like the look and what I have read about the 7501 Air Gap so I picked one up before I gave much thought into which carb I had. I am running an Edelbrock 1400 (EGR), the installation instructions for the intake say that I should be running a 1405 or 1406 (or bigger???)but looking at the specs the main difference to the 1400 is just that it is emissions compliant.
I have a 1969 Camaro, 350\TH350 Fuelie (Camel Hump) Heads that I am not sure on the spec and a cam that I am also not sure about, Doug's Try-Y headers and an MSD HEI.
So my question(s) are...
Is my current carb just fine?
Is anyone else using a similar setup and how is it working for you?
Does the EGR capabilities take away from performance or could I rebuild\rejet to get close to the 1405?
jeremywrags is offline
post #2 of 2 (permalink) Old May 30th, 14, 08:49 PM
Anne
Re: Edelbrock Air Gap (7501) with Edelbrock 1400 Carb
Just install a block-off plate on the egr flange. I'm not aware of any 1st gen Camaro having egr. It sucks.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
