Can you see ports without tearing down? - Team Camaro Tech
post #1 of 12 (permalink) Old Jun 1st, 14, 06:52 AM Thread Starter
Have a shop who did some not so good work. We agreed on what I wanted done when we started last year but seems most was forgotten by the time it happened. Just wondering if there was a way to "SEE" a degree of what was done without tearing it completely down?
Orange 69 Camaro is offline
post #2 of 12 (permalink) Old Jun 1st, 14, 06:57 AM
Re: Can you see ports without tearing down?
You could use an inspection camera I bet. The kind with a flexible snake with a camera at the end and a monitor.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #3 of 12 (permalink) Old Jun 1st, 14, 09:23 AM Thread Starter
wondered about doing that. I am old school so foreign to me. Do you go down thru carb or with carb removed??? Never saw one so dont know how big they are
post #4 of 12 (permalink) Old Jun 1st, 14, 10:27 AM
I bought one of those cheap 7mm USB inspection cameras off of E bay for about $18 and was happy with it for what I wanted to do. They come in various sizes, so I got the smallest I could find, 7mm. You need to hook the camera to the USB on a laptop, so this could be an issue.
I would remove the carb. The throttle plates would probably cause too much interference to bend down/around into the passages. It also fits into the spark plug hole to see the cylinders. Not bad for $18!
gwbutch is offline
post #5 of 12 (permalink) Old Jun 1st, 14, 11:11 AM
I'd at least remove the carb if you want to go in through the intake side. Harbor Freight has a cheap camera set up, but not as cheap as what gwbutch was talking about. It's also thicker by the looks of it. It's basically a flexible line about the with of a pencil with a camera in the tip. A quick google search will show you all you need.
Semper Fi!
HawkX66 is offline
post #6 of 12 (permalink) Old Jun 1st, 14, 11:18 AM Thread Starter
problem is no laptop to run it and prolly couldnt figure out how to anyway. Not sure I could even post a pic.
post #7 of 12 (permalink) Old Jun 1st, 14, 11:24 AM
The HF one doesn't need a laptop, but it's $89. Even with a 20% off coupon it still isn't really cheap.
Semper Fi!
HawkX66 is offline
post #8 of 12 (permalink) Old Jun 2nd, 14, 12:28 PM
What are you hoping to see? Porting job? Valve guides?
TC # 349
zdld17 is offline
post #9 of 12 (permalink) Old Jun 2nd, 14, 03:26 PM Thread Starter
see how well porting job was done
post #10 of 12 (permalink) Old Jun 2nd, 14, 03:44 PM
Lyle
remove the passenger side header/exhaust manifold and take a look in the ports?
probably much easier than pulling an intake manifold. Either way, you won't get a great look without getting right down to the intake and exhaust ports.
1969 Camaro Convertible
thebat is offline
post #11 of 12 (permalink) Old Jun 2nd, 14, 05:51 PM
OK understood. Many guys back in my day were hogging out ports , making them smoother that a pigs belly which in many cases in the wrong port, hurts.
Not to mention the fact that us older guys never had access to a flow bench much less heard of them. Some of us made port model templates that we found from some Jenkins or Yunick gru. If the template matches , that's what we did, match the contour but we were relying on someone else advice. We did not take in account going to the lightest valve with the largest port seat.
If the die grinder bounced, we had to replace valve seats. The intake sides were always prone to hitting a water jacket.
So unless someone is doing you a favor, I guess you should accept it but otherwise flow bench data sheet is more accurate.
My guess that you have stock heads? I can only guess the best I have seen is intake ports flow about 140/170 at 28" mercury. That's all I know about that.
I saved my self a few buck and lots of effort, I went for a CNC set of AFR 195's. Yep their expensive but you probably get your $$ worth on a set of the newer after market heads.
Really, I am not going to see all that airflow I paid for just cruising to the sonic.
If you don't trust your mechanic, who you gonna trust?
TC # 349
zdld17 is offline
post #12 of 12 (permalink) Old Jun 2nd, 14, 06:58 PM
Anne
Most of a good porting job is in the valve bowl.
No way to really see it without removing the valve itself. I use my finger to feel the radius under the valve seat to make sure it's consistent and smooth.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
