Re: Engine Leaking Fluid
It's just condensation. Those breathers you have let all the normal crankcase gases vent out under the hood and it's just condensing or clinging. To lessen it you're going to need to go to a PCV valve and an air cleaner setup that will allow attaching a tubed breather to it from the opposite valve cover. You could leave just one breather like you have and use a PCV but when you shut the engine off then the boil-off is going to vent out of it and possibly that oil filler cap you have. Drive one of your new cars for about twenty minutes, then pop off the oil filler cap to watch what comes out.
Don't worry, it's most likely not harmful blow-by. Every single time you run and shut off your engine, combustion byproducts and normal air condense in the engine and then steam-off the next time you drive your car.
'69 Camaro
500hp/538lbft
