Engine bog finally solved - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 1st, 14, 08:39 PM Thread Starter
foreverlookin's Avatar
Been having a running issue with a bog around 1900-2100 RPM running an EZEFI and had been blaming it on that and even took it in for dyno tuning with the hopes of fixing it but alas was still there.
In a moment of frustration called Fast for advise gave them all of the motor specs, cam, intake and they came back with perhaps the lifters were a little tight and to back them off a little which I did yesterday and it solved my problem 100% no more bog.
Just thought I would share this as if anyone else comes across the same issue it may save them some grief.
foreverlookin is offline
post #2 of 2 (permalink) Old Jun 1st, 14, 09:33 PM
Jerry
Re: Engine bog finally solved
Good info thanks for sharing.
69 SS/RS
565 BBC
Tremic 6 speed
Dragonfly Jones is offline
