Headers - Team Camaro Tech
post #1 of 18 (permalink) Old Jun 2nd, 14, 12:50 PM Thread Starter
Randy
Headers
Looking to put ceramic coated headers on my 69 Camaro with mild built 350. Anyone have any recommendations for some decent headers at a decent price also...Thanks
Randywisc is offline
post #2 of 18 (permalink) Old Jun 2nd, 14, 01:02 PM
Ty
69&76's Avatar
Re: Headers
Lots and Lots of options out there. These are inexpensive mid length headers and I am pretty sure they are ProComp. They make full length has well.
http://www.ebay.com/itm/SBC-350-Chev...e820de&vxp=mtr
I am sure they will require some massaging for the gear box, etc.
69&76 is offline
post #3 of 18 (permalink) Old Jun 2nd, 14, 01:08 PM
Re: Headers
Everyone's definition of decent price for a particular item can vary quite a bit, what's your budget for the set of ceramic coated SBC headers you are looking for?
NH69Z28RS is offline
post #4 of 18 (permalink) Old Jun 2nd, 14, 01:53 PM Thread Starter
Randy
Re: Headers
don't really have a budget just want a good pair, i don't mind paying a bit extra for a good pair. i currently have a new Flowmaster system on now with stock manifolds and 2 1/2 inch pipes. I am also thinking full length Headers. I am hoping for plenty of clearance for both installation as well as plug access.
post #5 of 18 (permalink) Old Jun 2nd, 14, 06:54 PM
Anne
Re: Headers
I like Hedman Elites. They have thicker 14 ga tubing and 3/8" flanges.
And they normally fit very well.
Be sure to break the coating in. Let it heat and cool several times without getting really hot.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #6 of 18 (permalink) Old Jun 2nd, 14, 07:49 PM
Re: Headers
Dynatech for fit, finish and the best quality. They make a complete system with headers and stainless pipes. They utilize stainless band clamps and all the original mounting points for the hangers. I have had the system on my car for 3 years and love it. They are not cheep but you get what you pay for.
http://www.afcodynapro.com/content/6...ro-small-block
http://www.afcodynapro.com/content/l...aro-68-72-nova
go to there website for more info
Good luck with your decision.
MJK-4 is offline
post #7 of 18 (permalink) Old Jun 3rd, 14, 10:25 AM
Re: Headers
I've had hedman elites on my 69z/28 350/330ho vortec motor with a muncie 4 speed for 11 years now. They've held up pretty well. The coating is starting to rust between the tubes down by the collectors and i had to clearance them when i put power steering in do to the raised ports in the vortec heads. My next set will probably be dynatech for power steering fitment reasons.
Dave69Z is offline
post #8 of 18 (permalink) Old Jun 3rd, 14, 05:59 PM
Re: Headers
Thorley 376Y1C for a street application , Above that Dougs D368.
TC # 349
zdld17 is offline
post #9 of 18 (permalink) Old Jun 3rd, 14, 11:30 PM
Neil
Re: Headers
Just test fitted a set of 740-21310 dynatech headers on my 67 camaro. They instal with ease But spark plug boot sits pretty close to pipe on cyl #3 "have afr 210 angle plug heads" and it also gets close to rag joint on stock power steering gear box. This was just a fast rough test fit. Other than that these headers fit and look really good.
67camaro07 is offline
post #10 of 18 (permalink) Old Jun 4th, 14, 10:50 AM Thread Starter
Randy
Re: Headers
Thanks guys, the Dynatech look nice, guess they don't give a good set away
post #11 of 18 (permalink) Old Jun 4th, 14, 11:25 AM
Todd
Re: Headers
I'm doing the final test fit on some new headers (mid-length and long-tube, stock port and raised D-port versions also) coming out from Hooker this week that you may be interested in. These are the first clean-sheet header designs for a small block in a 1st-gen that's come out in a few years as far as I know and they were CAD modeled to deal with a lot of the fitment issues mentioned here (spark plug and steering box clearance for example). I'll be photographing the installation, so if you want to see clearance photos of any area/angle just let me know and I can post them up for you. What transmission/steering set-up are you running on your car?
toddoky is offline
post #12 of 18 (permalink) Old Jun 4th, 14, 11:59 AM
kevin
Re: Headers
sorry to say, but I like my HOOKERS
flat tire is offline
post #13 of 18 (permalink) Old Jun 4th, 14, 12:01 PM
Re: Headers
Dynatech for sure great fit and awesome look you wont be disappointed
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline
post #14 of 18 (permalink) Old Jun 4th, 14, 05:25 PM
Keith
Re: Headers
Patriots fit great, are around $300-$350, are made by the same parent company that makes Doug's, and I was able to use the stock location for my clutch return spring...they also give great steering box clearance, so if I ever get around to putting in a power box, I'll still be in great shape!
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #15 of 18 (permalink) Old Jun 4th, 14, 07:14 PM
Todd
Re: Headers
Thanks for your support flat tire, if you've historically been a fan of Hooker headers, you will be very impressed with these new Hooker headers as they have features that move beyond what you normally get from Hooker/Headman/Dougs etc., such as TIG welded flat finished flanges, mild steel or stainless steel construction, included O2 bungs, stock A/C evaporator case compatibility and compatibility with the Ridetech Truturn system.
Both the mid-length and long-tube headers coming out will also be bolt-in compatible with the recently released Hooker 1st-gen F-body and 3rd-gen X-body exhaust systems.
toddoky is offline
