Header gaskets - Team Camaro Tech
post #1 of 13 (permalink) Old Jun 5th, 14, 11:12 AM Thread Starter
Header gaskets
What are the best sealing header gaskets for a big block with factory
aluminum winters square port heads.
1969 L89 is offline
post #2 of 13 (permalink) Old Jun 5th, 14, 11:40 AM
Chris
67RSSS's Avatar
Re: Header gaskets
Go with "copper gasket" hands down something like these will work.
http://www.ebay.ca/itm/SQUARE-PORT-C...-/130721963792
67 RSSS Van Nuys, 4th week Sept,1966
ps,tilt,headrest,spd warn,pw,am/fm,delux int,
remote mirror,rear defrost,tint glass.etc...
TKO 600 Extreme,12bolt 3:73 gears.
67RSSS is offline
post #3 of 13 (permalink) Old Jun 6th, 14, 02:29 AM
69z28freak's Avatar
Re: Header gaskets
Would this apply to small blocks as well. I was told Ram-Flex gaskets are the way to go.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #4 of 13 (permalink) Old Jun 6th, 14, 05:32 AM
Doug
Re: Header gaskets
Check out these gaskets from Summit Racing. http://www.summitracing.com/parts/sc...make/chevrolet. I haven't used them long enough to make review. They have got to be better than the hard paper gaskets. I have used the copper collector gaskets and I will not use anything else anymore.
Cdminter55 is offline
post #5 of 13 (permalink) Old Jun 6th, 14, 06:57 AM
Re: Header gaskets
X3 on some sort of copper gasket, I also used some of those locking header bolts, all the expanding and shrinking from the heat of the headers is what causes a lot of gaskets to fail as the bolts loosen up and loose even holding pressure accross the seal.
Don't have a long term review yet as car is still in project stage, but engine has been ran numerous times and so far so good on the seal.
PhantomRider is offline
post #6 of 13 (permalink) Old Jun 6th, 14, 09:15 AM
Chris
67RSSS's Avatar
Re: Header gaskets
Makes no difference if BB or SBC copper is the best way to go for header gaskets. I Also use copper head gaskets .
67RSSS is offline
post #7 of 13 (permalink) Old Jun 6th, 14, 09:34 AM
Chris
67RSSS's Avatar
Re: Header gaskets
The Rem- Flex ( Not Ram-Flex) gaskets are an option for those with warped matting surfaces. They are extremley pliable and help in sealing surfaces that are uneven. You will note that they are extremley thick. Keep in mind that these are also VERY FRAGILE and can break easily they require great care when installing and handling them.
The inexpensive headers with the thin header flanges are prone to warpage and often leak because of it. The Rem-Flex have being thicker fill in the gaps so to speak and offer a better matting surface in these instances.
67RSSS is offline
post #8 of 13 (permalink) Old Jun 6th, 14, 10:19 AM
Re: Header gaskets
I have used Percy's aluminum header gaskets, they were good, but the Rem-Flex's are awsome. I have had the RemFlex on my camaro and my friends 440 Challanger for 5 yrs now, they never come loose or leak. Great product,
With the Remflex you have to be VERY carefull not to bend them or they break. Remflex sent me a free replacement, even after I told them it was my fault it broke. Great customer service.
67 RS Convertible, 355ci, 650cfm, 5-speed, 12-bolt, 3.90 gears. 12.7 @ 110 mph
Marktat is offline
post #9 of 13 (permalink) Old Jun 6th, 14, 10:19 AM
Re: Header gaskets
Marktat is offline
post #10 of 13 (permalink) Old Jun 6th, 14, 10:24 AM
kevin
Re: Header gaskets
I have had great success with these
Mr. Gasket 7401G - Mr. Gasket Aluminum Exhaust Gaskets Details
•Reusable Colored Tie Straps
•Made From Dead Soft Aluminum
•Conforms Easily To Surface Irregularities
•Creates A Tight Leak Proof Seal
•Ideal For Race/Street/Tow Vehicles And Motor Homes
flat tire is offline
post #11 of 13 (permalink) Old Jun 6th, 14, 10:39 AM
Re: Header gaskets
I used to use Percy gaskets with Stage 8 locking header bolts when I was racing my 93 Z28. Never leaked or loosened up. The header bolts were 'spensive, but worth it if you don't like having to tighten up your headers all the time.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is online now
post #12 of 13 (permalink) Old Jun 6th, 14, 11:29 PM
69z28freak's Avatar
Re: Header gaskets
Thanks Chris. My Dyno guy in North Van Precision Racing Motors told me the same thing, that they are very brittle, but once installed they will never leak. I like the idea of having a header that you install once, then walk way. I currently have the aluminum ones on my car, but have not fired it up yet. Thinking of swapping them out.
What part of town are you in?
My Build Thread
post #13 of 13 (permalink) Old Jun 7th, 14, 01:08 AM
69z28freak's Avatar
Re: Header gaskets
These are the ones I have on my car now. Was curious how they compare to the Rem-Flex. Seems like both are a good option as are the copper units. I guess it comes down to cost and preference. I have no experience with header gaskets so I am doing the research now to learn a thing or two. Great Thread.
My Build Thread
