White smoke at higher RPMs - Team Camaro Tech
post #1 of 11 (permalink) Old Jun 5th, 14, 05:17 PM Thread Starter
Travis
I have a 68 with a 327. I have had it a few months. I know I have a small oil leak. Today I took it to work and on the way home on the highway I opened it up some and around 80mph in 4th gear I had plume of white smoke come out the back. When I let off the gas it stopped. I tried it again and it did it again. Other than that, the engine seems to be running fine. What is it and/or what do I need to look for? Thanks Travis
Mako1970 is offline
post #2 of 11 (permalink) Old Jun 5th, 14, 05:20 PM
Re: White smoke at higher RPMs
White smoke can be antifreeze. I would start with checking the intake gaskets for a leak.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #3 of 11 (permalink) Old Jun 5th, 14, 05:27 PM
Chad
cv2065's Avatar
X2....check your coolant levels as it may be leaking into the combustion chamber. Could be a blown head gasket.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #4 of 11 (permalink) Old Jun 5th, 14, 06:25 PM
68resto's Avatar
I'll be very interested when and what you find out. My Wife's 67 Firebird w/ a 326 would do the exact same thing. I decided to yank it out and put in a Chevy 350. I am finishing it this Saturday. I t only happened around 80 mph or if you stomped on it and stayed in it all the way (high rpm range). Oil was always clean but changed regularly and never noticed a loss of antifreeze.
68 Cloned RS/SS w/ all the goodies.
67 Firebird w/ a Chevy 350
67 Camaro 6 cyl. 68,000 original miles
w/ wife & kids w/ the same addiction.
68resto is offline
post #5 of 11 (permalink) Old Jun 5th, 14, 09:31 PM
Tim
Is there any milky residue on the underside of the oil filler cap?
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #6 of 11 (permalink) Old Jun 7th, 14, 12:49 AM
Kev
Sacrilege! Should have dropped in a 455
More seriously I'd think it was oil rather than coolant if it wasn't losing coolant. In the rear view, light blue may look white.
67sc is offline
post #7 of 11 (permalink) Old Jun 7th, 14, 04:57 AM
Garth
I think it sounds like oil, it's really difficult to see while your hanging on the steering wheel and looking in the rear view at smoke all at the same time.
Have someone follow you when you do this. See if it's from the tail pipe or under the car. Your small oil leak may get larger under pressure. If the crankcase isn't venting properly it will push extra fluid and the it gets on the hot parts and you have smoke.
If it's coming out the tailpipe you have different things to look for. If you have real dual exhaust with no cross over you'll be able to narrow down what bank it's coming from pretty quick too.
- antifreeze - your 'spotter' should quickly see it evaporate, it's water.
- oil - it's either pulling past rings or valves.
- oil - could be pulling it in through PVC
Look hard enough and you'll figure it out. If I was working on the car I would leak test the engine. Pressurize and close each cylinder, see where the air comes out.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
69L48Z27 is offline
post #8 of 11 (permalink) Old Jun 7th, 14, 07:24 AM
R/T
Jack
Could be pulling oil though the pvc
Matthew 22: 37-39
R/T is offline
post #9 of 11 (permalink) Old Jun 13th, 14, 09:56 PM Thread Starter
Travis
Thanks Everyone. I am looking into it.
Mako1970 is offline
post #10 of 11 (permalink) Old Jun 15th, 14, 04:21 PM
joe
If its auto trans, can also be sucking trans fluid
JOE58 is offline
post #11 of 11 (permalink) Old Jun 16th, 14, 05:10 AM
Steiner
Pull the plugs and they'll tell you whether it's oil or coolant.
'69 Camaro
500hp/538lbft
Steiner is offline
