302 z28 motor carb question? - Team Camaro Tech
post #1 of 29 (permalink) Old Jun 5th, 14, 06:25 PM Thread Starter
Rob
What size carb should I be running on a 302 built up motor? Has .546 cam, dart heads, and 11:1 compression. Also running a Muncie 4 speed, and 4:11 gears.
What size carb should be on this? I have a 750 double pumper and feel this is way too much. And I am leaning towards a 650. I am not racing this and will be just cruising around a few times a month.
Your thoughts?
Robgon is offline
post #2 of 29 (permalink) Old Jun 5th, 14, 06:53 PM
Camarodude67
Re: 302 z28 motor carb question?
750 is a stock setup for a 302, 780CFM was the original size carb in 1969.
camarodude67 is offline
post #3 of 29 (permalink) Old Jun 5th, 14, 06:57 PM
Cris
I have a basically stock 302,mild cam,stock heads and run an Edelbrock 750 and it runs great
csearls is offline
post #4 of 29 (permalink) Old Jun 5th, 14, 08:50 PM Thread Starter
Rob
What are your thoughts on a 650?
Robgon is offline
post #5 of 29 (permalink) Old Jun 5th, 14, 08:56 PM Thread Starter
Rob
Also what rpm does your car idle at?
Robgon is offline
post #6 of 29 (permalink) Old Jun 6th, 14, 05:29 AM
True, but I always thought that was a little big for a 302 unless you were really spinning it up. I'd think a 650 would be a better fit for cruising... maybe even a 600.
buenymayor is offline
post #7 of 29 (permalink) Old Jun 6th, 14, 01:35 PM
Gary
69Z28's Avatar
With a slightly modded 302, 12.0 pistons -140 cam, and some port work on stock 186 heads and 4.88's back in the 70's I ran a 750 dbl pump and loved it for the street. I recently ran a 4777 650 dbl pump on a stock spec built 70 LT1 in my Z and loved it. Only problem you really need to worry about is the price of gasoline. In the 70's gas was cheap, today it's a lot more and you will use it up fast with dbl pumpers.
06A 1969 Camaro Z28 X33D80 69 B 711 Black Stripes Console w/tach and gauges.
69Z28 is offline
post #8 of 29 (permalink) Old Jun 6th, 14, 02:28 PM
I tried a 650 on my 70 Z28 in '85 when the motor was 9:1. The engine ran out of air/fuel at 5,000 rpm, so I used a 3310 750 Holley and it was fine. I currently have the stock 780 Holley with 10.2 compression ratio with 4.10 gears and it runs fine too. The 650 is too small for the 302 or even a 350 with the Z28 cam.
You could borrow a friends 650 if they have one to try.
COPO is offline
post #9 of 29 (permalink) Old Jun 6th, 14, 06:33 PM
Cris
650 double pump might work out fine,with my edelbrock it idles nice at 750-800 rpm
csearls is offline
post #10 of 29 (permalink) Old Jun 6th, 14, 08:24 PM Thread Starter
Rob
Ok. I think I'll stay with a 750. I bought a quick fuel 750 dbl pumper with a electric choke. I'm having very low vacuum though and can't get it to idle at 759-800. Any suggestions?
Robgon is offline
post #11 of 29 (permalink) Old Jun 6th, 14, 08:53 PM
Gary
69Z28's Avatar
Have you just tried the stuck idle RPM? I'm thinking 900 or 950 should work fine. I'm running right at 1000 RPM idle with an over the counter 4053 and my engine like it there. That of course is the 70 LT1 spec 350 that is currently in my Z now.
69Z28 is offline
post #12 of 29 (permalink) Old Jun 6th, 14, 09:09 PM
scblucam's Avatar
302 12.5:1, 500/300 range cam 8in/hg vacuum 650 Demon double pumper works fine.
68 302 M20 - 85 IROC Z
scblucam is offline
post #13 of 29 (permalink) Old Jun 7th, 14, 04:44 PM
Get the timing up to 16* initial, 36* total. It should get the vacuum up to 10"-11" Hg.
COPO is offline
post #14 of 29 (permalink) Old Jun 8th, 14, 09:20 AM
James
stock idle speed on a 69 Z is 900 RPM... 800 is too low. can't hold vacuum with the overlap.
What power valves do you have in the carb?
If they are above the vacuum reading or close then the idle drops/loss of vacuum are causing raw fuel dumps everytime the vacuum drops off.
Power valves help the transition from idle to main fuel metering circuits.
Power valves should be 1.5-2" below the reading at idle, if it (vacuum reading) dithers up and down then the reading needs to be below the lowest reading you see, if it only hold 8" then get a 6 Power valve.
* Double Pumpers have a power valve on each metering plate.
James
"Collectin' Camaro's since only Rednecks Drove them"
firstgenaddict is offline
post #15 of 29 (permalink) Old Jun 8th, 14, 03:39 PM
I didn't think a power valve could kick in when your just idling, being on the idle circuit? I'll have to verify that in my Holley tuning book.
Holley in the past used the method of -2 from your vacuum reading at idle but have since changed to a more accurate method my taking 1/2 of your reading. If it's 8" at idle then I'd be using a 4.0. http://www.holley.com/data/TechServi...wer_valves.pdf
Mines 10 and I'm using a 5.0 and it works fine in my 70 LT-1 roller motor.
16* initial / 36* total
COPO is offline
