Intake on head has build up of rust sludge from water - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 6th, 14, 11:23 AM Thread Starter
Putting a small block back together after a tear down. It was sitting 5+ years. I don't know the history of it. Heads look pretty fresh. Have hardened valve seats, bronze guides. 8782461 heads. Looking into the exhaust ports it looked like a couple of the seals were leaking so I went to replace them. It only had the umbrella type and no O rings so I was going to install those. During the tear down I noticed one of the valves was a little rusty and the port had a build up of rust sludge. Where could it be coming from? I don't see evidence from either the intake or head gaskets. Would have been the #4 intake.
1968 Camaro -tear down in process
1967 Chevelle Malibu 396, 4 speed
jfoley is offline
post #2 of 6 (permalink) Old Jun 7th, 14, 07:29 AM
Re: Intake on head has build up of rust sludge from water
Bad head gasket leaking water from the cooling passages into the cylinder?
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is online now
post #3 of 6 (permalink) Old Jun 7th, 14, 04:40 PM
Get the head pressure tested, you could have a pinhole in the cast or a crack.
COPO is offline
post #4 of 6 (permalink) Old Jun 7th, 14, 04:59 PM
jno
Looks like maybe some leakage from the head gasket near the bottom coolant passage?
jno is offline
post #5 of 6 (permalink) Old Jun 7th, 14, 05:21 PM
Jonathon
Smitty68's Avatar
A leaky/worn valve seal can cause this. Once the damp air gets in it will slightly rust like this. I would have them manga fluxed and checked just in case.
68 Resto-Mod in progress..355sbc .350 Trans Rushforth wheels
My Build:
Smitty68 is offline
post #6 of 6 (permalink) Old Jun 7th, 14, 06:44 PM
Anne
If it's been sitting around 5 years the humidity in the air could have caused surface rust.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
