Increased torque from 383 - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 6th, 14, 03:01 PM Thread Starter
JPT
Hello all,
I have discussed this question with another forum member already, but I thought that I would put it out there for others to comment on.
I am anticipating putting a 430 HP/400+ torque sbc 383 stroker into a basic, unmodified 1969 coupe.
The question is-what material should the motor mount be (rubber, poly, delrin) to correctly handle the torque of the new engine?
Are there any other rubber parts that should be upgraded to a harder material to go along with the new engine's torque? My brakes and wheels are already upgraded or are about to be.
Thanks for your help.
John T.
jptonks is offline
post #2 of 3 (permalink) Old Jun 6th, 14, 03:12 PM
kevin
Re: Increased torque from 383
you can buy solid engine mounts
my engine produces 511 feet of torque. I use a turn buckle from the head to the frame. it is adjusted snug but still lets the engine have some freedom of movement
flat tire is online now
post #3 of 3 (permalink) Old Jun 6th, 14, 04:33 PM
DjD
DjD's Avatar
It's your choice... I have a 400ish HP/TQ 383 with stock mounts and no problems in the 10ish years it's been under the hood... Make sure you have good U joints and a decent trans mount and unless you are a track rat racking the miles 1320 feet at a time you'll be fine!
...Dennis
DjD is offline
