Camshaft Choice - Team Camaro Tech
post #1 of 16 (permalink) Old Jun 7th, 14, 10:14 PM Thread Starter
Robert
Camshaft Choice
Which camshaft would you select to upgrade a stock 327-210 that has 186 heads 2.02/1.60 valves with Z/28 manifold. Car is street driven only. Thanks.
ISKY CAMS 264-MEGA HYDRAULIC #CL201264
Advertised Duration IN/EX: 264/264
Duration @.050 IN/EX: 214/214
Gross Valve Lift IN/EX: .450"/.450"
Lobe Sep Angle / Intake Ctr Line: 108
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 2000-5800
Bracket Master II Lunati #10120416LK
Advertised Duration IN/EX: 265/265
Duration @.050 IN/EX: 216/216
Gross Valve Lift IN/EX: .458"/.458"
Lobe Sep Angle / Intake Ctr Line: 110/106
RPM Range: 1000-5000
1969 Camaro RS Hugger Orange - Work in Progress - You see rust, I see restoration!
rsb0719 is offline
post #2 of 16 (permalink) Old Jun 7th, 14, 11:42 PM
Larry
larryh56's Avatar
Re: Camshaft Choice
Went through this with my 327. Having tried a couple cams my advice would be to run them both through a dynamic and static compression calculator and read this: http://members.uia.net/pkelley2/DynamicCR.html
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #3 of 16 (permalink) Old Jun 8th, 14, 04:48 AM
Re: Camshaft Choice
I'd go for the Lunati camshaft.
It can still use the stock springs, might change over to Z/28 springs though, 125-135 lb seat pressure.
Everett#2390 is online now
post #4 of 16 (permalink) Old Jun 8th, 14, 07:36 AM
Re: Camshaft Choice
Lunati
COPO is offline
post #5 of 16 (permalink) Old Jun 8th, 14, 08:51 AM Thread Starter
Robert
Re: Camshaft Choice
Thanks Larry, Everette and Mark. I will go with the Lunati Camshaft as suggested. Larry reading about DCR is a little too technical for an old guy like me with no mechanical background. Thanks again everyone. Great site!
rsb0719 is offline
post #6 of 16 (permalink) Old Jun 8th, 14, 02:46 PM
Wes
Re: Camshaft Choice
Need more info before anybody could make a worthwhile recommendation:
What tranny?
What rear gears?
What's your CR?
Any vacuum requirements?
What exhaust system?
Goals for your car?
Straight-line-69 is offline
post #7 of 16 (permalink) Old Jun 8th, 14, 03:14 PM
Re: Camshaft Choice
Good low end torque and HP. Works well
with stock stall converter. Good idle.
http://www.lunatipower.com/PDF/Lunati-Catalog.pdf
COPO is offline
post #8 of 16 (permalink) Old Jun 8th, 14, 07:11 PM
Randy
Re: Camshaft Choice
Im using Comp Cams XS274 solid in my 327.
1967 camaro, 327, 9.7 CR, comp cam xs274solid, vortec cylinder heads, edelbrock vortec performer rpm, 750 annular carb, HVH 2" spacer, msd pro billet w/6A box, turbo 350 trans, 3500 stall, 4:10 gears, caltracs suspension, m/t drag radials.
rkmjbad67 is offline
post #9 of 16 (permalink) Old Jun 9th, 14, 02:42 PM
Chris
Re: Camshaft Choice
OEM heads need duration split.
Chris
cstraub is offline
post #10 of 16 (permalink) Old Jun 9th, 14, 07:23 PM
Anne
Re: Camshaft Choice
You only live once ! Go roller :
217/225 @ .050"
http://www.summitracing.com/parts/hr...make/chevrolet
Good idle, street performance, strong lower to midrange. Stock converter OK.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #11 of 16 (permalink) Old Jun 9th, 14, 09:22 PM
Gary
69Z28's Avatar
Re: Camshaft Choice
If your going hydraulic, I like the GM 350/350. I used that cam in a .030 over 327 with #041 1.94-1.50 heads, blackjack headers and an early GM aluminum intake...I think it was either a 65 or 66 intake I bought off a corvette guy back when I first started messing with engines in the early 70's, added a 650 dbl pumper to top it off. Engine ran real good with 3.55's. Of course there are much better cams out there now but you can't beat old school GM stuff if your engine is relatively untouched.
06A 1969 Camaro Z28 X33D80 69 B 711 Black Stripes Console w/tach and gauges.
69Z28 is offline
post #12 of 16 (permalink) Old Jun 9th, 14, 09:41 PM
Vega$69's Avatar
Re: Camshaft Choice
I like the Isky if you have a manual tranny
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #13 of 16 (permalink) Old Jun 9th, 14, 10:06 PM
Lynn
Re: Camshaft Choice
I agree with Gary... if you have an automatic tranny. Hard to beat the L46 camshaft.
If you have a stick, use an LT-1 camshaft. Available from Rock Auto made by Fed Mogul.
With either of those you can use the stock springs (won't tear up the cam as easy) and still rev to 6800 if you want to.
Hate to start the old "zinc in modern oil" debate again, but if you are going flat tappet, either hyd or solid, then use Mobil Delvac (available at Wally World) or if you must use a synthetic, use half a bottle of GM's EOS with each oil change. Good insurance against wiping a lobe.
Lynn
bilodeaulynn is offline
post #14 of 16 (permalink) Old Jun 9th, 14, 10:09 PM Thread Starter
Robert
Re: Camshaft Choice
What tranny? 350 TCI
What rear gears? 12 bolt with 3.73:1
What's your CR? 9.5
Any vacuum requirements? Power Disc Brake all 4 wheels
What exhaust system? Magnaflow 2.5
Goals for your car?
Street driven only
Distributor MSD 8360
I believe the Lunati is a good cam as suggested.
rsb0719 is offline
post #15 of 16 (permalink) Old Jun 14th, 14, 07:19 PM Thread Starter
Robert
Re: Camshaft Choice
I contacted Lunati and the guy there said, "The cam I would run is part number 10120701. This cam is 213/219 at .050, 454/.468 on the lift, and it is cut on a 112 LSA with a 108 intake
centerline." I guess your suggestion was on the money.
rsb0719 is offline
