Need some ideas - Team Camaro Tech
post #1 of 1 (permalink) Old Jun 11th, 14, 06:58 AM Thread Starter
Bob
MileHigh69's Avatar
Need some ideas
I have a GMPP HO454 with Fuel Injection and a Procharger D1-SC with stock cast iron heads. I believe it has about 525 HP. I would like to bump the performance a little. Maybe a more aggressive cam and aluminum heads. I need suggestions on a bumped up cam that idles well but is more aggressive. I know the cast iron stock heads don't flow a ton of air. Looking for ideas. Part numbers are good.
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
