Help Me Find Chevy High Performance Article - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 11th, 14, 11:54 AM Thread Starter
Joe
327 Small Block Chevy Engine Build - The 500HP Question
For This 327, The Answer Is Yes-And Then Some
By John Nelson
Photography by Henry D
The article is dated November 1, 2008
I don't know what issue of Chevy High Performance Magazine that this came from.
Can anyone help me track this down, and/or send me a copy, along with the dyno charts and build sheet for this engine.
Willing to $$$ anyone who can help.
Thank you,
Joe
1965tripleblack is offline
post #2 of 7 (permalink) Old Jun 11th, 14, 12:05 PM
Vintage 68's Avatar
Wink Re: Help Me Find Chevy High Performance Article
Try 'Google'n' "CHP 327 500HP"
Hint - it's the 1st entry at the top of the results page ...
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 7 (permalink) Old Jun 11th, 14, 01:54 PM Thread Starter
Joe
Thanks.
I already have EXACTLY that.
What I need is the build sheet that was included with the paper copy.
There might have been a dynorun as well.
post #4 of 7 (permalink) Old Jun 11th, 14, 02:10 PM
Vintage 68's Avatar
327CI Build Sheet
Specifications not listed are the same as stock. Except as noted, all dimensions are in inches or fractions thereof. All prices sourced through JGM Performance Engineering and AFR.
Displacement 333 ci
Bore x Stroke 4.040 x 3.250
Compression 11.52:1
Rod center-to-center 6.000 inches
Piston deck height +0.005
Chamber volume 60 cc
Rod bearing clearance 0.0022
Crank endplay 0.0060
Piston ring endgap 0.026 top, 0.020 second
Main bearing cap torque 70 ft-lb (moly-lube)
Rod bolt torque 65 ft-lb (moly-lube)
Head bolt torque 70 ft-lb (moly-lube)
PRICE LIST
Ackerly & Childs 9771-45 gap-to-fit moly rings $130
AFR 1095 195cc SBC Eliminator Comp cylinder heads $2,079
8041 1.580-inch solid roller valve spring upgrade $207
8508 titanium retainers $129
ARP 134-2501 balancer bolt $27
134-3703 12-point High Performance head bolts $138
434-2101 12-point stainless intake bolts $39
134-5402 main studs $52
134-7901 oil pump drive shaft $13
Autolite AR3910 spark plugs $40
BEP 70082 front cover $35
Canton 15-246 SBC F-body RR Power Pan $485
20-013 SBC pickup 3/4-inch tube $40
Comp Cams 12-773-8 solid roller cam $367
818-16 solid roller lifters $430
1105-16 Hi-Tech stainless rocker arms $480
Eagle S/R 6000SBLW 6-inch I-beam rod $299
Engine Tech CC400 cam bearings $17
EP155 oil pump, 3/4-inch pickup $33
Federal Mogul/Fel Pro 1010 0.039-inch head gaskets (2) $146
1206S-3 intake gaskets $33
TCS45121 front cover gaskets $13
1880 one-piece oil pan gasket $43
138M 10 race main bearings $98
8 7065CH 10 race rod bearings $90
2912 rear main seal $31
GM N/A stock replacement 327 balancer $100
14011012 water pump $130
(labor on 1964 327ci two-bolt main block) thermal
clean and magnaflux block $108 bore and hone block with dual-torque plates
$308 align and hone main journals with ARP studs $188
regrind & micropolish factory steel small-journal crank $134
balance rotating assembly $250
custom blueprint and assemble long-block $850
dyno test and tune $750
KB Performance KB155 +40 pistons $454
Manley 25716-16 5/16-inch, 0.080-inch wall pushrods (+0.200) $180
Moroso 60461 cam button $18
93020 valve cover gaskets $62
MSD Ignition 83645 digitial HEI Module $182
8225 HEI Coil $117
Pro Gear PG4100-1TB timing set, 1/2-inch pitch with Torrington bearing $150
Total $9,475
ADDITIONAL ITEMS
AED Performance 950 HO Performance Carburetor $700
Slover Porting Service fully ported Super Victor intake (porting only) $450
Read more: http://forums.superchevy.com/chevy-h...#ixzz34MaYDgK0
1968 Convertible
Some trucks
post #5 of 7 (permalink) Old Jun 11th, 14, 02:50 PM Thread Starter
Joe
327CI Build Sheet
Displacement 333 ci
Compression 11.52:1
PRICE LIST
8225 HEI Coil $117
Total $9,475
ADDITIONAL ITEMS
Thank you.
Now all I'd like to see are the dyno sheets and when this thing starts making torque with that big cam, big intake, and HUGE carburetor.
The build sheet already tells me a lot!
Mine runs a dual plane, 750 CFM and slightly smaller cam and makes 414 RWHP @ 6700. Makes 300 ft-lbs @ less than 2400. Very streetable and driven everywhere, including long road trips.
Now, how did they arrive at FWHP from RWHP?
post #6 of 7 (permalink) Old Jun 11th, 14, 04:02 PM
Smile Re: Help Me Find Chevy High Performance Article
TJS69 is offline
post #7 of 7 (permalink) Old Jun 11th, 14, 04:57 PM Thread Starter
Joe
Originally Posted by TJS69 View Post
Thanks TJS69.
