secondary shaft spring keeps popping off - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 14th, 14, 12:51 PM Thread Starter
Gordon
gordr's Avatar
I've got a 7037211 Quadrajet carb and the outer secondary shaft spring pops off once in a while and I've got to do a hard resetting in of that spring. Yesterday it popped off again and taking a good look at it I can see that my secondary's throttle shaft cut-groove in it is perpendicular up and down when the shaft plates are closed. Doing an image search on the web shows me that all the other ones I came up with have that cut-groove slit in line with the secondary throttle plates, side-to-side when the plates are closed. So, that's why I'm forcing my spring in there as it's going around too far due to the perpendicular cut-groove slit in mine. Attached is a pic to show, the secondary throttle plates are closed but the slit is almost perpendicular. Maybe all along I've had the wrong shaft? I can't see anywhere where I could adjust that cut-groove slit to put in the position that's best.
67 Plain Jane being assembled with 427, 4 spd Muncie, 12 bolt rear with Mosers, 4 wheel discs
gordr is offline
post #2 of 4 (permalink) Old Jun 15th, 14, 08:46 AM
Re: secondary shaft spring keeps popping off
Get a nylon bushing in the hole or fill the gap with JB Weld (reg) not quick dry. Or a nylon tube jammed into the hole then trim both sides.
COPO is offline
post #3 of 4 (permalink) Old Jun 15th, 14, 09:59 AM Thread Starter
Gordon
gordr's Avatar
It's not the hole itself as it's a snug fit into the hole.... WHY is my cut-groove slit almost up and down perpendicular/vertical whereas most of the others I see are from side to side horizontally. HOW can I adjust the cut-groove slit to the proper side to side position horizontally? from the looks of it it's a solid secondary shaft....I'm hoping somehow I can adjust that cut-groove slit to horizontal. Anyone have any ideas on that?
gordr is offline
post #4 of 4 (permalink) Old Jun 15th, 14, 02:25 PM Thread Starter
Gordon
gordr's Avatar
I found the cut-groove slit to be in the correct position for that setup, not sure why mine's different. Someone sent me a pic, below, of the proper way to have the spring oriented in there. Used heavy duty grips and that to bend the spring winding inwards to get it into good position, here's hoping it lasts a while.....
Name:	Quadrajet secondary shaft spring setup 67 Camaro 396.jpg
gordr is offline
