motor cable tie downs - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 17th, 14, 03:13 PM Thread Starter
Randy Mitton
wondering if these cable engine tie downs were used on all v8 engines,mine are still on and curious, as my motor is not a performance motor by any means,thanks in advance, Randy
Randy Mitton is offline
post #2 of 8 (permalink) Old Jun 17th, 14, 03:45 PM
Jack
Re: motor cable tie downs
Search this site for motor mount recall or go here http://www.autosafety.org/chevrolet-motor-mounts
69 Z28 x77 Hugger Orange / Deluxe Houndstooth / M21 / 4:10 posi / Canadian Docs
Jack92584 is offline
post #3 of 8 (permalink) Old Jun 19th, 14, 05:29 AM
The cable tie downs were used on engines with solid throttle linkages, when the motor motors deteriorate the engine would lift on the left side and go to wide open throttle, (and actually experiencing its gut wrenching) Later GM introduced a new style motor mount that has a metal tab under a hoop between the upper and lower portions of the mount, if you have these new style mounts no need to keep the cables.
Rob.Canada is offline
post #4 of 8 (permalink) Old Jun 19th, 14, 07:35 AM
Rob was bang on. There were a few of surprised drivers back then, althought the cables were usually tossed and lost.
capt
Bumper sticker- I'm not SPEEDING
I'm QUALIFYING!
captcanuck68 is offline
post #5 of 8 (permalink) Old Jun 29th, 14, 01:15 PM
JohnZ's Avatar
The restraining cables were part of the motormount recall, issued in 1971, two years after the 69's were built. The cables were never installed on the assembly line - only by dealers doing the recall fix.
JohnZ
CRG
JohnZ is offline
post #6 of 8 (permalink) Old Jun 29th, 14, 01:56 PM
kevin
just to be safe, I still use a 3/8 turn buckle fastened to the head and to the frame
flat tire is offline
post #7 of 8 (permalink) Old Jun 29th, 14, 07:01 PM
Robert
I have them on my Camaro, both sides, however passenger side is a single cable wrap around the exhaust manifold and motor mount. I believe this was used on air condition cars; I don't have air however.
1969 Camaro RS Hugger Orange - Work in Progress - You see rust, I see restoration!
rsb0719 is offline
post #8 of 8 (permalink) Old Jun 29th, 14, 09:27 PM
Roger
rogerh's Avatar
I am sure the recall was for all first gens with V-8s. This is a copy of the recall letter. Also is a picture of the old motor mounts with a separated one at the top. The new mounts are interlocking with rubber between the metal plates.
Roger
rogerh is offline
