327 210 pistons? - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 17th, 14, 06:21 PM Thread Starter
Larry
Send a message via AIM to Pentagon Larry
327 210 pistons?
Does anyone know what pistons and overall compression a 1968 327 210 HP has? Thanks for your time.
Pentagon Larry is offline
post #2 of 7 (permalink) Old Jun 17th, 14, 06:46 PM
6T8
Jeff
Re: 327 210 pistons?
My Chilton's book says:
Top Compression 0.013-0.023
Bottom Compression 0.013-0.025
This is "Ring Gap"; not sure if that's what you need...
6T8 is offline
post #3 of 7 (permalink) Old Jun 17th, 14, 06:56 PM
Bill
The 210 horse engine has a flat top, cast aluminum, 4 valve relief piston, assuming they are original to the block. The 300 horse and 250 horse engines used the same piston. IIRC the 210 had a 9.5 to 1 compression ratio which was derived from a large combustion chamber in the cylinder head. The 300 horse had a different head with a smaller chamber size which yielded a 10.5 to 1 compression. I hope this helps.
Bill
sbcBill is offline
post #4 of 7 (permalink) Old Jun 17th, 14, 06:58 PM
The pistons are just basic flat-tops. Compression ratio is 8.75:1, and compression is 160psi, depending on how you meant the question. Source for that is the Chassis Service Manual.
1967 RS driver with a 327/210... but now with an M20, HEI, AAW harness w/ halogens and relays, Dakota Digital, Moto-Lita, TMI interior, and a few other toys
Brian_P is offline
post #5 of 7 (permalink) Old Oct 27th, 14, 04:55 PM
Mike Petrovich
This site indicates that the 67-68 327 pistons were impact extruded alloy aluminum (as opposed to cast alloy aluminum):
http://www.chevy-camaro.com/parts/ch...des-piston.htm
Not sure about that, this seems to indicate cast alloy aluminum:
http://www.camaros.org/l30m20.shtml
1968 327 sport coupe. Son of original owner.
mike p is offline
post #6 of 7 (permalink) Old Oct 29th, 14, 10:12 AM
JohnZ's Avatar
That link brings up a "Forbidden" error page, but if it says impact-extruded (forged) pistons, it's wrong. The ONLY small-block Camaro with forged pistons was the Z/28. Period.
JohnZ
CRG
JohnZ is offline
post #7 of 7 (permalink) Old Oct 29th, 14, 11:27 AM
Mike Petrovich
Thanks for the info JohnZ, I thought the IE 327 piston info might be incorrect.
I'm not sure what happened to that piston page, I was just on there a couple days ago.
It looks like the main site is still online:
Maybe someone called them on the incorrect info, and they took the piston page down.
This site posts the same piston info (in a more primitive format):
http://www.holisticpage.com/camaro/parts/piston.htm
You can see they also listed some 396 and the 427 pistons as impact-extruded.
mike p is offline
