383 with Comp Cams 270HR roller - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 18th, 14, 03:51 PM Thread Starter
JPT
Hello all,
Today I looked at a newly assemled crate engine with the following specs- High nickel 2 piece rear seal block, 383 Eagle rotatiing assembly, flat top pistons, Comp Cams 270 HR hydraulic roller cam, Comp Cams roller rockers, Edelbrock RPM Performer Air Gap intake, and MSD HEI distributor.
The cylinder heads are nothing special- Chevy 1.94/1.55 heads. Compression ratio is estimated to be 10.0 to 1.
The owner estimates the horsepower is 410 and the torque is 430.
I have my doubts with those heads and the mild specs on the roller cam.
We will most likely run a quick Fuel 680 or 700 cfm carb on this engine.
Based on the great experience level out there, does anyone have an opinion as to the horsepower and torque from this engine combination?
If I were willing to add just a little higher quality cylinder head what would you guess the horsepower and torque would be?
Thanks for your help.
John T.
jptonks is offline
post #2 of 7 (permalink) Old Jun 18th, 14, 05:04 PM
Re: 383 with Comp Cams 270HR roller
Heads are really choking it a lot....
Get some 200-210cc heads with some 2.05/1.6 valves and wake that thing up
Then I'd say close to 500/480 ? (with a little more compression too)
68 Camaro~LSx ~all motor
post #3 of 7 (permalink) Old Jun 18th, 14, 05:46 PM
Vega$69's Avatar
X2. Some decent Alum Heads will make a big diff.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 7 (permalink) Old Jun 18th, 14, 08:37 PM Thread Starter
JPT
Anyone have a horsepower and torque estimate on the engine desribed?
jptonks is offline
post #5 of 7 (permalink) Old Jun 19th, 14, 03:32 AM
I'd say the owner is close....no desktop dyno here.
post #6 of 7 (permalink) Old Jun 19th, 14, 08:08 AM
Sean
What is the combustion chamber size? I know with my 65cc AFR's, flat tops would have put me way high in the static compression ratio department. With the longer stroke of the 383, I had to run a dished piston to get 10:1.
I agree with the others, no sense in choking it with a poor flowing head.
1969 Z28 Clone/383 SBC/Holley #4779 750DP w/HP center section/Tremec TKO600/Dutchman 9"/Pypes 3" race pro/Doug's D368/ 17x8, 17x9 VWW/Nitto 555
omalley1537 is offline
post #7 of 7 (permalink) Old Jun 19th, 14, 08:56 AM
Brandon
with the specs you are listing, I would say 350-375HP/400-430TQ is more realistic. A good set of Pro-Filer 195cc or Dart SHP 180cc Alum heads and you will be in that 430+HP/460+TQ range.
71 Chevelle 496 Stroker Hyd Roller 675HP, TH400 3500 Stall, 3.73 12 Bolt.
ATK HP ENGINES
Custom Built Street-Strip-Racing Engines
Notalent is offline
