Installing Accel dist in 350 - Team Camaro Tech
post #1 of 16 (permalink) Old Jun 22nd, 14, 12:31 PM Thread Starter
So I gave up on my msd and bought a Accel performance distributor which is a 59107 model.
Find out the directions say transfer your coil from old cap. I dont have one,,,its the old style female spark plug wire MSD cap and the coil is in the box
Consulted both Summit catalog and my parts store where I bought it. We dont have such a thing,,,no info available.
Does anyone know what it takes to FIND and what model works??? Directions say something about a 59107 model only or does that mean that model dist only??
Orange 69 Camaro is offline
post #2 of 16 (permalink) Old Jun 22nd, 14, 01:32 PM
kevin
Re: Installing Accel dist in 350
I BELIEVE THIS IS WHAT YOU NEED
Home
Online Catalog
Brands
Customer Service
Track Order
View Cart
Search
Search
Make/Model
Search from over 10 Million Auto Parts
Select Your Vehicle:
Choose Year:
Select Year2015201420132012201120102009200820072006200520 04200320022001200019991998199719961995199419931992 19911990198919881987198619851984198319821981198019 79197819771976197519741973197219711970196919681967 19661965196419631962196119601959195819571956195519 54195319521951195019491948194719461945194419431942 19411940193919381937193619351934193319321931193019 29192819271926192519241923192219211920191919181917 19161915191419131912191119101909190819071906190519 04190319021901
Fast Shipping
30-Day Money-Back Guarantee
Lowest Prices
1974-1987 Chevrolet Camaro Ignition Coil Standard Motor Products
Click to Enlarge
(1 Reviews)
Standard Motor Products Ignition Coil
Sale Price:
$16.58
Quantity:
Select Year 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987
In Stock
Part Number: 14027-07035628
Condition: New
Shipping Options:
Ground
This Part Fits the Following: Warehouse: C
Notes: Ignition Coil -- Electronic Ignition
Vehicle
• 1974 Chevrolet Camaro
Vehicle Engine
• 1975 Chevrolet Camaro 5.7L V8
• 1976 Chevrolet Camaro 5.7L V8
• 1976 Chevrolet Camaro 5.0L V8
• 1977 Chevrolet Camaro 5.7L V8
• 1977 Chevrolet Camaro 5.0L V8
• 1978 Chevrolet Camaro
• 1979 Chevrolet Camaro
• 1980 Chevrolet Camaro 3.8L V6 VIN: K
• 1980 Chevrolet Camaro 5.7L V8
• 1980 Chevrolet Camaro 4.4L V8
• 1980 Chevrolet Camaro 5.0L V8
• 1981 Chevrolet Camaro 5.0L V8
• 1981 Chevrolet Camaro 3.8L V6 VIN: K
• 1981 Chevrolet Camaro 5.7L V8
• 1981 Chevrolet Camaro 4.4L V8
• 1982 Chevrolet Camaro 5.0L V8
• 1983 Chevrolet Camaro 5.0L V8
• 1984 Chevrolet Camaro 5.0L V8
• 1985 Chevrolet Camaro 5.0L V8
• 1986 Chevrolet Camaro 5.0L V8
• 1987 Chevrolet Camaro 5.0L V8 CARB
Title 1974-1987 Chevrolet Camaro Ignition Coil Standard Motor Products 74-87 Chevrolet Ignition Coil 79 78
Description 1974-1987 Chevrolet Camaro Ignition Coil, Chevrolet Camaro Ignition Coils, Standard Motor Products Ignition Coil, Standard Motor Products Ignition Coils SKU: 14027-07035628 Ignition Coil -- Electronic Ignition Engine Electrical 3.8L, 4.4L, 5.0L, 5.7L, V6, V8, K, CARB 74-87 Chevrolet Ignition Coil. Replacement Chevy Ignition Coil Parts. 1974 1975 1976 1977 1978 1979 1980 1981 1982 1983 1984 1985 1986 1987 74 75 76 77 78 79 80 81 82 83 84 85 86 87
Product Category Vehicles & Parts > Automotive Parts > Automotive Engine Parts > Automotive Ignition Parts > Ignition Coils
Product Type Engine Electrical > Ignition Coil
Authorize.Net Merchant - Click to Verify
flat tire is online now
post #3 of 16 (permalink) Old Jun 22nd, 14, 02:13 PM
madmax87's Avatar
If you have a 59107 distributor now I don't see why this wouldn't work.
http://www.summitracing.com/parts/ac.../applications/
madmax87 is offline
post #4 of 16 (permalink) Old Jun 22nd, 14, 02:26 PM
Doug
This should work. Call Summit Racing to make sure. Put out 48000 volts too.http://www.summitracing.com/parts/acc-140013
Cdminter55 is offline
post #5 of 16 (permalink) Old Jun 24th, 14, 05:45 PM Thread Starter
Ok got all this figured out and trying to get buttoned up and installed. coil installed, cover installed.
Have a couple questions if you can help.
#1 there seems to be so little room between firewall and dist cap that the cap hold down hits the firewall as you turn the dist. How much clearance does it need? and is a hammer and punch applied liberally to the firewall the only answer?
#2 the switch wire ///hot wire issue still haunts me. There are no heavy wire coming thru the firewall from the switch itself,,,just a light wire that is wired to my old MSD box or coil. A relay was suggested but have NO idea how that works. Any advice??
#3. Lastly which port do I use to connect my vac advance to?? lots of capped hoses all over intake and carb?
Thanks for any help,,,I am struggling as I have never had a system like this before. Its been 40 years since twisting any car wrenches,,,but it is fun.
post #6 of 16 (permalink) Old Jun 24th, 14, 06:45 PM
Steiner
#1. A hammer works but you can also pull the two bolts out of the transmission mount and shim the transmission up some which will move the distributor away from the firewall. Just make sure the fan doesn't hit the shroud. I've found that 3/4 inch of trans movement affects driveline angle by less than a degree so there shouldn't be an issue there.
#2. Run a new 12 AWG wire from the IGN spade on the fuse block inside the car to the BATT connector on the distributor. Just need a female spade connector and the existing BATT connector.
#3. Follow the instructions to adjust the vacuum advance canister down to around 10-12 degrees of timing, then connect to a manifold vacuum source. If you can't figure out where one's at, it should be one of the carb nipples that is below the throttle plates on the bottom of the carb. Pop off a cap and the engine should rev up.
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 16 (permalink) Old Jun 24th, 14, 07:01 PM Thread Starter
re: #3 the 3/32 allen wrench furnished with the dist. should work right?? WRONG. Either it was wrong size with dist. or inside was smaller. Got it adjusted using a 2.5 metric tho,,,just my luck,,all bad!!!
Now I find the new wires i bought wont work. Have headers so need straight boots,,except for cyl.6 which needs an angle boot cause so close to header. I see those wire heat protectors for like 25 bucks,,,are they a good deal?? Seems wires are very close to heat source big time. "IF" I had ends laying around for the male terminals on the cap I would just use the old wires splicing on a new end on them. I had the old style female cap.
post #8 of 16 (permalink) Old Jun 24th, 14, 07:11 PM
DjD
DjD's Avatar
Before you use it, send the large body dist back and find a small body electronic to replace it...
...Dennis
DjD is offline
post #9 of 16 (permalink) Old Jun 24th, 14, 08:48 PM
Rufas
The best way would have been to use the MSD box, trigger dist and remote coil, or, go with a small-body HEI.
Now, you have NO recourse but to bash the firewall in, to gain clearance, but, the dist will get even closer to the firewall when the trans is in gear, moving the vehicle down the road.
If someone suggests changing the engine or trans mount to get firewall clearance, politely thank them for their suggestion, and RUN AWAY, as fast as you can, that will only cause drive line angle problems you really don't want, nor, need.
BTW, that ACCEL coil shown, the BIG one, sits closer to the firewall than a stock coil down inside the cap cavity does.
dave ray is offline
post #10 of 16 (permalink) Old Jun 24th, 14, 09:21 PM
Steps
Rubbish m8 Read stieners post above.. run a search on older posts going back around 10 yrs.. and u WILL find originally there where 2 different factory trans mounts... something I discovered accidentally back in the 80s when originally going to the GM hei and compare my original factory mount with the modern low replacement.
Steptoe is offline
post #11 of 16 (permalink) Old Jun 24th, 14, 09:27 PM
Doug
[QUOTE
Now I find the new wires i bought wont work. Have headers so need straight boots,,except for cyl.6 which needs an angle boot cause so close to header. I see those wire heat protectors for like 25 bucks,,,are they a good deal?? Seems wires are very close to heat source big time. "IF" I had ends laying around for the male terminals on the cap I would just use the old wires splicing on a new end on them. I had the old style female cap.[/QUOTE] Checkout these ends to see if they will work. I just bought them for my Taylor wires that had female ends.
post #12 of 16 (permalink) Old Jun 25th, 14, 08:03 AM
Steiner
I've done both the math and hands on testing of this on my own car while chasing a rattle. A full 1" of trans movement up or down results in approximately 0.7 degrees of angle change which is negligible....especially since moving the trans up results in the same as moving the pinion down.... which if you absolutely have to move it for some reason..... is the way you want to go with it if it's even close to being parallel with the trans (which a stock car will often not be).
It's also (as I've found) the wrong way to try to align a TKO to get the right driveline angle since you can barely get an angle change compared to shimming the rear as a TKO almost hits the floor as is. Not even worth the trouble really if you're more than a degree off of where you want to be. A Muncie or other has a heap more room though. I've also run as much as two degrees down on the pinion compared to the trans (while chasing the rattle) with no effect on smoothness or ujoints as their angles were still within spec.
'69 Camaro
500hp/538lbft
Steiner is offline
post #13 of 16 (permalink) Old Jun 25th, 14, 08:35 AM
I went with the Accell Extreme wires on my 68 BB396 with headers, they are ceramic straight booted, so far so good and I have a few basically touching headers and no issues or signs of burn through. I had issues with wires burning and also did not like the sloppy look of the socks over the wires and still seemed to allow heat transfer that made wires feel brittle and dried out, did prevent burn through, but still just seemed to cut life of wires down due to heat transfer.
PhantomRider is offline
post #14 of 16 (permalink) Old Jun 25th, 14, 09:18 AM
Rufas
"Rubbish"
WILL YOU BACK OFF, AND, STOP POSTING YOUR CRAP. We here are trying to help the OP, NOT confuse him further with stuff that does not work.
Now, if someone will do an experiment, or, even better, more than one of you, go out and start the car up, have someone hold the foot brake down, and in gear, add fuel, and WATCH THE ENGINE MOVE, report it back here.
I am usually the person for a hundred miles in any direction that has to fix the idiocy done with things like steptoe's farces, to all sorts of vehicles, and the way I found this wasn't in math, although I am very good at math, but, by actually watching an engine move in a pickup truck chassis, when put in gear, after the engine was "repositioned" by a very reputable chassis shop in So. Cal., to allow clearance for the big cap HEI that had been stuffed into it, against the firewall. This wasn't the only truck butchered up this way, more than a few from the same pickup club had the same chassis shop, do the same work, with the same results, only about a half inch clearance between coil/cap and firewall, NONE when in gear and revved up.
Also, pinion angle is critical, it is finite, and NOT "adaptable", get it wrong, and the result isn't good at all.
Just why is it always an absolute war to get the good, truthful, accurate info out to those that ask for it, past all the smoke, mirrors and bull?
Me, I have worked for Duntov directly, at Skunk Works, on development of engines AND the large cap HEi, and do same for a MotoGP team right now, engine design/development, and have worked for Holley, Shelby, and other venues for many years. I do not know how I got so stupid from responding to steptoe's inaccurate blatherings. Enough is enough. I do this stuff EVERY DAY, fix things others profess to work, that flat do not, EVERY DAY.
Phantom Rider, the ceramics are a good way to go if you need protection from header heat, they work well to keep the wires working the way they should, good on you for your insight.
Let's help the OP, NOT make it worse for him, PLEASE.
dave ray is offline
post #15 of 16 (permalink) Old Jun 25th, 14, 03:47 PM
Steps
Hmm Steiner explanation above . and funny the HE?I in my camaro fits fine and pinion angle fine...with the lower height and factory correct high trans mount.
As to truck chassis etc ... these are forums about camaros, not trucks....
yeah m8 we are all stupid, havnt a clue what we are talking about, everything we are saying is BS right? 30 /40 years of hands on experience, not just on camaros, but vintage cars from around the world,. classic cars, from 2 cylinder to 12, fuels from old leaded, aviation, propane , methanes etc octanes from 63 to 135....
and u are the 'professional' who does it for a living....where/ what is your shop ?
Chill out m8 customers are waiting.
Steptoe is offline
