Misc engine install questions - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 23rd, 14, 10:35 AM Thread Starter
Randy
Hey guys, been out of action for more than a year due to health issues but lately been feeling well enough to get greasy again. Pulled my old 350 sbc out of my standard 1969 camaro with m20 tranny. Unbolted the bellhousing from the tranny and only pulled the engine.
Questions #1) I noticed that when I look at the tranny from the front of the car it appears to be tilted to the driver's side. Meaning the mounting bolts on the passenger side seem to be slightly higher than the ones on the driver's side. I looked underneath and it appears to be mounted correctly, is this normal?
Questione #2) I need a new flywheel and looking for recommendations. I have a built 383 stroker - 430HP, 400+ftlbs torque, manual M20 tranny. Internally balanced. Do I need anything special or will a standard 350 flywheel be fine?
Question #3) engine and engine frame mounts -replacing all the mounts, frame and engine mounts. Wanting to get the poly mounts, any recommendations? Also heard that the 69 frame mounts are "special" any issues there?
Thanks a ton guys!
Randy
1969 Cheverolet Camaro - Pro Touring
2018 Dodge Challenger R/T ScatPack 392 Shaker Hood Hemi
2016 BMW R1200rs
1976 Honda CB550 - I restored
il_randyb is offline
post #2 of 2 (permalink) Old Jun 23rd, 14, 06:56 PM
Re: Misc engine install questions
Thanks a ton guys!
Randy
1.That is normal. The transmission is sitting on the rubber mounted tail shaft bushing. The bell housing will tie it together when you bolt it to the engine.
2.You can use a standard 350 flywheel but you need to make sure it is zero balance. You can also buy a zero balance billet flywheel. Was the engine built with a flywheel? If so, that is the one you want to use if you don't know if it was balanced as an assembly.
3. There is a short and tall motor mount. The short is 1.5 inches from the block mounting surface to the center of the bolt hole. The tall is 2 1/8 inches. I am not sure about the frame stands. Someone else might reply with that info.
Good luck with your build
MJK-4 is offline
