Changing 350 cam instructions - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 23rd, 14, 11:12 AM Thread Starter
Does anyone have step by step instructions on how to change out my camshaft for my 69 350?
daxman is offline
post #2 of 3 (permalink) Old Jun 24th, 14, 01:14 PM
Robert
Re: Changing 350 cam instructions
Check this out, should have the information you need.
http://www.2quicknovas.com/tech.html
1969 Camaro RS Hugger Orange - Work in Progress - You see rust, I see restoration!
rsb0719 is offline
post #3 of 3 (permalink) Old Jun 26th, 14, 10:32 PM
ben
Carb off dizzy out intake off valve covers of rockerarms off pushrods out lifters out water pump off remove the fuel pump loosen or pull oil pan pull harmonic Balancer take off timing cover unbolt cam gear take chain off put cam gear back on with out the chain this will make getting the cam out easy and finaly pull the cam you will have to also pull the radiator to make room if the motor is in the car. I know is not very detailed but you Tube and Google are you best friends
67-396sbc is offline
