68 Z Carb to intake Gasket - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 4th, 14, 07:31 PM Thread Starter
kev
What type of gasket was used on a 68Z? I have seen several different types advertised and need the correct type and style configuration for this restoration.
1969396 is offline
post #2 of 5 (permalink) Old Aug 5th, 14, 08:36 AM Thread Starter
kev
Re: 68 Z Carb to intake Gasket
Does it use the completely open style, the on with 4 openings or the one with 2 holes and 2 that are open?
1969396 is offline
post #3 of 5 (permalink) Old Aug 5th, 14, 09:06 AM
Eric
Thin paper style gasket completely open.
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Vintage Musclecar is offline
post #4 of 5 (permalink) Old Aug 5th, 14, 09:14 AM
I've always used a thicker gasket to help keep the carb base cooler. I've gone with the 70 Z28 NA9 Cal heat shield for my Norwood 70 Z28. You can see the thickness in this photo and you can get different thicknesses at any speed shop.
COPO is offline
post #5 of 5 (permalink) Old Aug 5th, 14, 10:37 AM Thread Starter
kev
Thank you. I do not recall the metal heat shield on original 68 Z's. Is this a factory or after market trick for keeping the carb and gas cooler?
1969396 is offline
