383 flat tappet breakin - Team Camaro Tech
post #1 of 24 (permalink) Old Oct 2nd, 14, 08:40 AM Thread Starter
I spent a lot of time over the past few days going through all (most?) of the oil posts regarding zinc.
I ended up buying a case of Brad Penn 10W-30 oil that should be here tomorrow.
Assuming I get far enough along to actually start this newly built engine in the next couple of weeks, what do I need to do to break it in properly.
I've read/heard two different schools of though on this:
1) Run the engine for a minimum of 20mins at a minimum of 2500rpm
and
2) Constantly run the motor at varying speeds, preferrably driving on back roads for 30mins or so, the idea being that you don't want it to run at the same RPM for an extended time.
Obviously at odds with each other.
The engine will likely be ready to start before the car is "driveable", so should I wait and do #2, or can I start it up in the garage and break it in without being on the road quite yet.
Hanging on the Maine Coast...moved back North
1969 RS/SS, 383, 4spd, 373s, 12bolt, FatMat, Vintage Air - Super Red, and it's my first Camaro.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #2 of 24 (permalink) Old Oct 2nd, 14, 08:55 AM
Anne
Re: 383 flat tappet breakin
and
Here is the breakin procedure from Crane Cams :
http://www.cranecams.com/uploads/breakin/548e.pdf
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #3 of 24 (permalink) Old Oct 2nd, 14, 09:16 AM
Ty
69&76's Avatar
I have done about 8 motors in recent times and have always used the same oil you bought. I have done it the same way each time 20 min at 2500 rpm.
Be sure to prime the oil pump first.
69&76 is offline
post #4 of 24 (permalink) Old Oct 2nd, 14, 09:29 AM
Jonathon
Smitty68's Avatar
I agree with Ty on this one Jim, what he suggests should be fine when you decide to bring it to life.
68 Resto-Mod in progress..355sbc .350 Trans Rushforth wheels
My Build:
Smitty68 is offline
post #5 of 24 (permalink) Old Oct 2nd, 14, 09:47 AM
Bryon
bcm66's Avatar
Check with the company that you got the cam from for THEIR instructions.
I am from the "vary the RPMs" school - which is very similar to what Crane says to do in that link above.
68 Camaro SS 396 - 468 BBC now, M21, 12 bolt 3.73 coded housing but w/ 3.31 gears.
Looking for 68 Camaro with body number NOR 181016
CRG -
bcm66 is offline
post #6 of 24 (permalink) Old Oct 2nd, 14, 11:06 AM
kevin
I was told to use joe gibbs hot rod 15-50
flat tire is offline
post #7 of 24 (permalink) Old Oct 2nd, 14, 11:06 AM Thread Starter
It's a Crane...and I went through their break in instructions. They say to go straight to 3,000rpm, get it running smooth, and then vary it from 3,000 down to 1,500, and back to 3,000 for 20-30mins.
My neighbors are going to LOVE that
Engine pics
Radiator pics
Build album
Lobstah is offline
post #8 of 24 (permalink) Old Oct 2nd, 14, 11:29 AM
Bryon
bcm66's Avatar
From 7. in the break in instruction from Crane above, these are what it says...
Start the engine and immediately bring to 3,000 rpm. Timing should be adjusted, as closely as possible, to reduce excessive heat or load during break-in. Get the engine running fairly smoothly and vary the engine speed from 1500-3000 RPM in a slow, to moderate, acceleration/deceleration cycle.
During this time, be sure to check for any leaks and check out any unusual noises. If something doesn’t sound right, shut the engine off and check out the source of the noise.
Upon restart, resume the high idle speed cycling. Continue the varying “break-in” speed for 20 - 30 minutes. This is necessary to provide proper lifter rotation to properly mate each lifter to its lobe.
The important thing is to vary the RPMs in a slow to moderate cycle.
CRG -
bcm66 is offline
post #9 of 24 (permalink) Old Oct 2nd, 14, 11:44 AM
Use Joe Gibbs BR oil for your breakin. They also sell BR30 breakin oil.
COPO is offline
post #10 of 24 (permalink) Old Oct 2nd, 14, 12:44 PM Thread Starter
I bought this specifically for the zinc content:
Brad Penn 009-7150-12PK 10W-30 Partial Synthetic Racing Oil - 1 Quart Bottle, (Case of 12)
Only concern is that it's "partial synthetic"...
***edit***
Went back and found Brad Penn Break In oil...straight 30W, so bought 4 quarts of that. Will used the 10W-30 after it's been on the road for awhile.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #11 of 24 (permalink) Old Oct 2nd, 14, 07:30 PM
Chris
Only way cam gets oil on lobe is from the crank throwing it up. Overfill the crankcase ONLY DURING BREAK IN. Put 10 qts in it.
Chris
cstraub is offline
post #12 of 24 (permalink) Old Oct 2nd, 14, 08:32 PM
Cory
making sure the engine fires right up helps alot too! grinding away over and over wipes off cam and lifter lube!! a little too much timing is better then not enough (red headers, and gets hot)! also be prepared, have a plug in fan ready, enough fuel, timing light hooked up, a few helpers to watch for leaks. give one person the job to watch oil pressure gauge and instruct them to shut off motor is oil pressure drops for some reason. if for some reason it needs to be shut off, this is not bad. just dont let it idle. on restart let it come up in rpms right way again.... hope this helps make it smoother for you!
68_camaro_rs_convt is offline
post #13 of 24 (permalink) Old Oct 3rd, 14, 07:35 AM
click's Avatar
Here is another great break in oil to consider and equally great assembly lube
AMSOIL break in oil
Assembly Lube
click is offline
post #14 of 24 (permalink) Old Oct 3rd, 14, 03:22 PM Thread Starter
AMSOIL break in oil
Assembly Lube
Assembly lube is already in there, albeit it's 4yrs old
And my Brad Penn break in oil arrives Monday.
Engine pics
Radiator pics
Build album
Lobstah is offline
post #15 of 24 (permalink) Old Oct 3rd, 14, 05:59 PM
Larry
I have always covered the cam lobes and lifters with Molycote assembly paste and used a break-in oil when available. I also use a big blower that blows air into the radiator to simulate highway speed air and do the break in sitting in the driveway.
Back before I knew about the molycote we would use STP oil treatment and coat the cam & lifters with that. Cannot remember ever having a problem doing it this way either. We did use a drill attachment to prime the oil pump and get lube up to the top end a bit as well.
L Holmes is offline
