1967 camaro 327 camshaft problem - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 13th, 14, 12:04 AM Thread Starter
So once again I have an engine issue. I am worried that I didn't break in the camshaft properly. So the engine is together. But, I worry because I didn't have a tacometer when I let it run to break it in.
I took off the valve covers and the valve rockers. I have measured the travel distance of each of the push rods. This should be the lift of each cam lobe...right? What worries me is that I get an exhaust lift of about .30" and a intake of about .275". I say about because I am using a marker. Although these numbers are fairly consistent for each of the 8 cylinders, they seem very low. Does this mean that I have damaged the cam and need to replace it?
Thanks for any help.
mjarenal is offline
post #2 of 5 (permalink) Old Oct 13th, 14, 03:20 AM
steve
Re: 1967 camaro 327 camshaft problem
Don't forget to multiply the lift numbers by 1.5 for the rocker arm ratio. I have had camshaft failure before, it started with valve train noise, followed by rocker arms that were always loose. If your valve train looks like its all moving about the same you may be ok. Pull your oil filter, dump it out into a clean pan. Then cut it open, if the cam has failed there will be a lot of metal in the filter
grampstoyz is offline
post #3 of 5 (permalink) Old Oct 13th, 14, 07:29 AM
Some people with new FT cams fire it up and go for a drive and the cam is ok.
COPO is offline
post #4 of 5 (permalink) Old Oct 13th, 14, 10:23 AM Thread Starter
I didn't realize that you have to multiply by 1.5. Also, didn't think about pulling the oil filter. Good idea. I'll try that next. Thanks grampstoyz.
mjarenal is offline
post #5 of 5 (permalink) Old Oct 19th, 14, 09:50 PM Thread Starter
No metal in the oil filter. Hope the cam is ok. I'm going to run it next weekend. Thanks guys.
mjarenal is offline
