Do I need to run a heater hose by pass? - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 19th, 14, 09:53 AM Thread Starter
JC
Send a message via AIM to JC69RSZ28
I have removed the heater unit with plans to run vintage air but in the mean time I have just plugged the heater hose inlet and outlet. Does anyone foresee a problem with that?
Could this prevent good coolant flow?
JC
1969 Hugger
JC69RSZ28 is offline
post #2 of 4 (permalink) Old Oct 19th, 14, 10:12 AM
Re: Do I need to run a heater hose by pass?
If it's a gen 1 small block Chevy, then yes - just install pipe plugs in the intake and the water pump and you'll have no problems. BBC or LS motor I can't say for sure.
BPOS is offline
post #3 of 4 (permalink) Old Oct 19th, 14, 10:24 AM Thread Starter
JC
Oh I for got to say it's a small block chevrolet 350
1969 Hugger
post #4 of 4 (permalink) Old Oct 19th, 14, 01:51 PM
Steps
Or simply by pass the heater with one of the hoses till get the new unit in.
Think about it
the hose goes from the engine.. into a vaccuum flow on off 'switch, into the hear , out of the heater back into the engine.
So what happens when u turn the heat off with the controls? the vacuum switch in effect blocks all flow as if the inlet and out lets on the engine had been capped off.
Steptoe is offline
