Ring Blow By??? - Team Camaro Tech
post #1 of 13 (permalink) Old Oct 20th, 14, 11:26 AM Thread Starter
Ring Blow By???
If the rings have a lot of blow by, would I see traces of oil in the intake and exhaust ports of the head.. I have a real lot of crankcase pressure, blowing the dipstick out of the tube, and now putting a second set of intake gaskets.. There is no trace of oil or gum anywhere.. The motor is brand new. 427 sbc 10.5-1,Hasting rings..020 gap. high volume oil pump..600 lift mechanical roller. The heads are Victor Jr. cnc ported..The motor is only pulling 12-15 vacuum, and at high rpms, I don't think the pcv is working with the sudden drop of vacuum. there is a breather on the drivers side and pcv on psgr side.. at a idle, the pcv is sucking like a SOB. Any other suggestions..
Heatmaker is offline
post #2 of 13 (permalink) Old Oct 20th, 14, 11:32 AM
Re: Ring Blow By???
I've got higher than normal vacuum reading at the oil dip stick (6") when it should be (1-3") when I tested it so I'm picking up one of these small orifice hallowed out PCV valves to see if it helps.
GM no longer stocks them but were used on many cars/trucks that had a high oil consumption.
COPO is offline
post #3 of 13 (permalink) Old Oct 20th, 14, 11:37 AM
Fred
Re: Ring Blow By???
Hi Steve. So you decided not to hijack huh?
First, PCV'S don't work much under load. Load = little to no vacuum.
If your engine is blowing out the dip stick, I think you've got bigger problems than an improperly located PCV. (it needs to be on the drivers side)
128.79mph 1.428 60'
Fred Ficarra is offline
post #4 of 13 (permalink) Old Oct 20th, 14, 11:59 AM Thread Starter
Re: Ring Blow By???
Thanks Fred , No hijacking today, this car is driving me nuts.. Bigger problems? can you give me some suggestions?
post #5 of 13 (permalink) Old Oct 20th, 14, 12:15 PM
Fred
Re: Ring Blow By???
Sure Steve. Excess crankcase pressure only comes from your combustion chambers. That rules out bad valves because they aren't tied to the crankcase.
That means pressure is not being contained in one or all of the cylinders. You could have a cracked piston, or bad rings. The block is probably OK if you're not loosing coolant to the pan.
First, I'd do a compression test. (quick and easy) Then go from there. Hell, you might even have a missing ring. When you pull the plugs for the test there's a good chance you'll see a bad one and know how to proceed.
128.79mph 1.428 60'
post #6 of 13 (permalink) Old Oct 20th, 14, 04:22 PM
Re: Ring Blow By???
Or cly leak down test .
TC # 349
zdld17 is offline
post #7 of 13 (permalink) Old Oct 21st, 14, 09:28 AM
Rick
Re: Ring Blow By???
Yup. My compression test was 180 in every cylinder on my Bel Air. Leakdown was blasting out the oil fill tube before I even got past 20# pressure in the cylinder.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #8 of 13 (permalink) Old Oct 21st, 14, 09:50 AM
Re: Ring Blow By???
Compression test tells if pressure can be made
Cylinder leak test tells how well the pressure can be held - a better test as suggested.
Welcome RickD - long time
Everett#2390 is online now
post #9 of 13 (permalink) Old Oct 21st, 14, 10:01 AM
Rick
Re: Ring Blow By???
Thanks!
Rick Dorion
RickD is offline
post #10 of 13 (permalink) Old Oct 21st, 14, 10:08 AM
alex
Re: Ring Blow By???
More than likely you have some broken rings or a busted ring land with that kind of blow by on a new engine or both. In any event engine has to come out and be taken apart and evaluated as to the cause . Hastings rings are great piston rings used them for years . Alex
ss27 is offline
post #11 of 13 (permalink) Old Oct 21st, 14, 11:42 AM
Re: Ring Blow By???
Or rings stuck in the ring glands. I made a mistake of putting too much Indian head shellac around my head studs. Some dripped into the cly and walls, top rings picked it up. Made the entire power tour on low power until I got home and ran a leak down on each cly. Found the leak quick.
Yes, Hastings , Ramco or PC rings are good as long as they are moly, no chrome please.
TC # 349
zdld17 is offline
post #12 of 13 (permalink) Old Oct 21st, 14, 09:04 PM
Wes
Re: Ring Blow By???
Actually, the opposite is true. A PCV valve is fully open during lower vacuum signals (under a load for instance when there's the most blowby which all engines have to a degree) and the PCV valve is closed or almost closed at higher vacuum conditions (idle, cruise, deceleration).
Straight-line-69 is offline
post #13 of 13 (permalink) Old Oct 22nd, 14, 05:04 PM
Fred
Re: Ring Blow By???
OK, apples and oranges. If you're talking about the valve internal setting under load vs. cruise, that's one thing. But if you're needing to check out how much crankcase air is moved, then that's done under high vacuum conditions. Full throttle just lets blow-by out to the air cleaner because vacuum is non existent.
To insure the crankcase is healthy I perform a quick test by pulling the PCV valve and hold it clear of the valve cover. One can expect smoke from both valve covers even on a healthy engine. It's the amount of smoke that tells the tail.
Another fun check is to remove the passenger side tube to the air cleaner and cap it with the palm of my hand while the engine IDLES. Vacuum should glue my palm to the tube. Yeah, those tests don't work at full throttle for a variety of reasons.
After re-reading your assertion Don, no, I disagree. I think it's the other way around. But that depends on the 'tune' of the valve I suppose.
128.79mph 1.428 60'
