External Balance - Team Camaro Tech
post #1 of 11 (permalink) Old Oct 22nd, 14, 12:51 PM Thread Starter
Jon
External Balance
I am looking at purchasing a crate 450hp 383. It uses an externally balanced crank, in a late model roller block. Builder says that I will need to purchase a 400 balancer and a late model 350 wighted flywheel. Should I be concerned about the balance tolerance of purchasing these parts? If I go with name brand stuff, will the balance be good enough for a 5500 rpm street engine? I understand it's best to balance the internals with the flywheel & balancer, but that's not possible with a crate motor.
Jon
JD4020 is offline
post #2 of 11 (permalink) Old Oct 22nd, 14, 01:10 PM
Re: External Balance
Pretty sure the factory roller blocks used a 1 piece rear main seal, although there is a kit that will allow you to install a 2 piece RMS. The flyheels/flexplates will not interchange between the two - different bolt circles. Make certain you know what you're getting. There are scads of ext balanced 383s running around. I'd have felt more comfortable had the machinist had these parts in hand when the engine was built/balanced.
BPOS is offline
post #3 of 11 (permalink) Old Oct 22nd, 14, 01:47 PM
Wes
Agree with BPOS,..doesn't make sense.
If you're not running her often on the dark side of 6000 RPM (you said 5500 would be tops), here's the crank you need:
http://www.summitracing.com/parts/sca-935050l
...this is:
* for 5.7" rod,
* 3.75" stroke
* one-piece rear main (for your roller-block),
* 350 mains,
* internal balance (uses neutrally balanced flywheel and balancer)
* Scat's "cast steel" 9000 series
* 51 lbs,
* $243 with free shipping (can't beat it)
Internal balancing is the way to go.
Good luck!
Straight-line-69 is offline
post #4 of 11 (permalink) Old Oct 22nd, 14, 02:39 PM
Brandon
All 1pc seal blocks stock were ext balance rear/internal balance front cranks. Most Scat/Eagle kits come this way, I use hundreds of them a year and there is not a problem with them.
If he is using a ext balance front & rear setup, that's just a cheaper budget kit that only Eagle does, maybe a few other sub par companies. It would be ok for what you are doing.
71 Chevelle 496 Stroker Hyd Roller 675HP, TH400 3500 Stall, 3.73 12 Bolt.
ATK HP ENGINES
Custom Built Street-Strip-Racing Engines
Notalent is offline
post #5 of 11 (permalink) Old Oct 22nd, 14, 02:42 PM Thread Starter
Jon
I am considering a Blueprint 383. They specify an 8" 400 balancer and a late model 350 flywheel will be required. My concern is how well balanced it will be with aftermarket parts, not used during balancing. I know they build a lot of these, so maybe it should not be a concern.
JD4020 is offline
post #6 of 11 (permalink) Old Oct 22nd, 14, 03:09 PM
Brandon
No comment on there stuff...Just do a search.
ATK HP ENGINES
Notalent is offline
post #7 of 11 (permalink) Old Oct 22nd, 14, 03:17 PM Thread Starter
Jon
Yeah, I'm not looking for comments regarding Blueprint itself. I've already searched plenty. I'm really just looking for comments regarding the balancing. Thanks.
JD4020 is offline
post #8 of 11 (permalink) Old Oct 22nd, 14, 03:35 PM
From Blueprint engines, request a bob weight card if possible.
As for the balancer and flywheel, purchase good stuff, not the china brand.
Sounds like you already purchased this motor? I would get it running asap as I have heard of many complaints that were let go and the warranty went out.
Even better, round up the parts you need and take them to a shop that does engine balancing. That way you know what is happening.
As for the 9000 series cast crank, I have heard good stuff behind it. Its not a forged crank but it will be good for under 7k rpm.
You need to mock this stuff up before you go the balance shop. Make sure your piston bottom balance pads clear the crank throw.
Remember, the 400 balancer is what keeps this motor in balance.
What was said about the flywheel interchange is correct. Late model one piece cranks and early model cranks hubs have a different id.
As mentioned , do a search on the company, issues are out there on this site.
https://www.camaros.net/forums/showthread.php?t=191597
TC # 349
zdld17 is offline
post #9 of 11 (permalink) Old Oct 22nd, 14, 04:08 PM Thread Starter
Jon
Thanks for the info. No, I haven't purchased yet, just trying to get in front of any issues, or talk myself out of it. I've researched a lot, and feel comfortable with BP, in general.
I've got a 509 2 bolt 400 ready to be built, but all the shops I've taken it to, want $6500+ to build me a 450/450 engine. Kind of hard to justify the $$ for a weekend cruiser, when I can by a BP crate for $3700.
JD4020 is offline
post #10 of 11 (permalink) Old Oct 22nd, 14, 04:49 PM
Fred
Doesn't that raise a red flag with you? Are you asking us to tell you that your rationalization is OK?
128.79mph 1.428 60'
Fred Ficarra is offline
post #11 of 11 (permalink) Old Oct 22nd, 14, 04:57 PM
Consider a crate motor with a factory warranty, for a few $$ more. Takes all the worry and guess work out of the picture.
https://sdparts.com/details/gm-perfo...parts/12498772
I think $6500 for a cast motor is too high, I built my own 383 with forged parts for under 6k. Course I spec'd the motor to what I wanted to do, Cruise long distances.
TC # 349
zdld17 is offline
