Re: Need help choosing a cam
I'm not sure that I'd go with a 'probably' diagnosis. Find someone who can give you an accurate reading of what is going on. Replacing a cam, then lifters, valves and who knows what else can get expensive, and your issue could still remain. Maybe post a video or audio clip and some of the fine folks here can point you in the right direction. A mechanics stethoscope also goes a long way to pinpointing where exactly the sound is coming from.
Good luck!
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
