filling the Radiator - Team Camaro Tech
post #1 of 13 (permalink) Old Oct 26th, 14, 06:35 AM Thread Starter
Bob
MileHigh69's Avatar
I have a big block,454 with a long pump. I cant seem to get the air out. Anybody have some tried and true methods for filling a big block Chevy without having air bubbles.
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
MileHigh69 is offline
post #2 of 13 (permalink) Old Oct 26th, 14, 06:46 AM
Re: filling the Radiator
Jack up the front of the car or squeeze the upper rad hose when your close to full.
COPO is offline
post #3 of 13 (permalink) Old Oct 26th, 14, 06:49 AM
Try parking the car on a slope so that the radiator fill is higher than everything else.
You may want to install a temporary overflow can with a vacuum siphon pressure cap (different than the one you have now, as it allows fluid back in when it is cool). That way you can fill the radiator to the top and all of the air will all escape while driving without loosing or spilling coolant into the environment. After a couple of heating cycles the coolant level can be lowered with a turkey baster to the correct cold fill level.
Big Dave
Larger Dave is offline
post #4 of 13 (permalink) Old Oct 26th, 14, 08:23 AM
Kevin
Try drilling a small hole in the thermostat flange. Kevin
KRhat is offline
post #5 of 13 (permalink) Old Oct 26th, 14, 09:03 AM
Doug
Drilling a 1/8" hole in the thermostat works, I have been doing this for years. Another way I have tried is removing the thermostat and filling the block from the top. Reinstall the thermostat and housing along with the top radiator hose. Fill the radiator and your done. Test run the vehicle and check all the fluids.
Cdminter55 is offline
post #6 of 13 (permalink) Old Oct 26th, 14, 09:35 AM
Chad
cv2065's Avatar
You can also get one of these. I have one and it works pretty good.
http://www.amazon.com/Lisle-24610-Spill-Free-Funnel/dp/B001A4EAV0
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #7 of 13 (permalink) Old Oct 26th, 14, 10:16 AM
JohnZ's Avatar
That's what I've always done, never had an "air bubble". I modified a plastic funnel years ago by adding a bunch of holes so it sits up square in the thermostat opening by itself - I can see the coolant level rise so I stop pouring before I make a mess.
ID:	90442   Click image for larger version
JohnZ
CRG
JohnZ is offline
post #8 of 13 (permalink) Old Oct 26th, 14, 10:48 AM
Keith
X2...fill from the thermostat opening in the block...you can jack up the front of the car, so the block fills completely by the time the coolant reaches the t-stat opening...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #9 of 13 (permalink) Old Oct 26th, 14, 03:53 PM
Steps
The hole in the thermostat is good because allows a little flow before it starts to open.. which allows more accurate temp gauge readings...
It doest take much to start the thermostat to open, exceeding any hole....which means any air goes thru early ... which means the hole drilled does squat for air bleeding.
Also of note these old cooling systems are designed to have a couple inches of air in the radiator at hot and even more cold.
The hole and bleeding in real life is a fallacy.....
Simply by jacking the front of the car up....filling the radiator, the coolant goes into the engine thru the bottom pipe, filling the engine.....yes there will be a few bubbles trapped, in a couple cnrs, and on the rough walls.....
The moment the coolant starts to move.. thermostat even 1/2 open, the volume going thru the engine above abut 1500 rpms is huge... with excellent turbulence, washing any remaining air into the COUPLE INCHES AIR GAP in the top of the radiator...
issue can occur if a radiator is mounted too low , or have components like a IMPCO LPG convertor mounted above the top of the radiator....
If u keep getting air bubbles with a full radiator cap off... start to consider something like a blown head gasket.... check the cooling system for hydrocarbons/ COx
Steptoe is offline
post #10 of 13 (permalink) Old Oct 26th, 14, 05:26 PM
69-Pace's Avatar
I'm still a fan of using the cooling system to flush out air. Slightly elevate the front end. Remove the radiator cap. Fill to the cold line and leave the cap off. Start the car and reach operating temp. As the thermostat opens the water pump will force all air to the highest point - the radiator. Add antifreeze as needed to the hot line. Let the thermostat cycle open at least three times on a big block, twice always does it on a small block. Shutdown, lower car to level and check fluid level. Cap and done.
Sent from my iPhone using Autoguide
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #11 of 13 (permalink) Old Oct 26th, 14, 06:05 PM
Get an UView Air Lift. It makes filling the coolant system really simple and you can check for leaks before a drop of antifreeze is poured in the system. It uses shop air to put the system under a vacuum. if the vacuum falls off then you check for leaks. If vacuum holds, then you hook the hose to a bottle of mixed coolant (we use a clean 5 gal bucket with 4 gallons of mix) and fills the entire system without a spilled drop.
They can be had for under 150 bucks (found ours at a swap meet for $60) and you will wonder why you have lived with out one.
69 RS/SS X22 51-51 Dusk Blue coupe in resto......still.
69 X11 355 ci M22 3:73 12 bolt...current driver
Spooky is offline
post #12 of 13 (permalink) Old Oct 26th, 14, 06:08 PM
like this one: http://www.amazon.com/UView-550000-Airlift-Cooling-Checker/dp/B0002SRH5G
Spooky is offline
post #13 of 13 (permalink) Old Oct 26th, 14, 07:16 PM Thread Starter
Bob
MileHigh69's Avatar
Thank you for all the great ideas. i will try a couple out.
