factory big block solid lifter intake - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 27th, 14, 02:13 PM Thread Starter
Cory
i want to know what is the manifold hieght on the factory solid lifter dual plane intake. i am building an oval port big block and would like to get an intake that looks a close as possible to an original. i would like to use the 396 style air cleaner for the cowl hood. i have a mill so i can make some adjustments in hieght if need be.
68_camaro_rs_convt is offline
post #2 of 5 (permalink) Old Oct 27th, 14, 03:23 PM
Re: factory big block solid lifter intake
If you run a stock style dual plane intake , you should be fine, but its the low profile bottom air cleaner base that plays a big part in this set up.
I am not up to stock bbc intakes but I think they are all the same as long as they are dual plane. http://www.jegs.com/webapp/wcs/store...1&YEAR=1541407
Some of the BBC experts will pop in on this, maybe Fred is out there somewhere.
TC # 349
zdld17 is offline
post #3 of 5 (permalink) Old Oct 27th, 14, 03:47 PM
Wes
The only GM oval port aluminum intake for a BBC was used on late 60's Vettes (390 HP 427's) and it's a pancake; not much for performance.
Higher performance (solid lifter) intakes for BBC's were all rectangle ports.
Unless you just have to have GM, the Edelbrock RPM O-port dual plane is a great piece:
http://www.summitracing.com/parts/ed...make/chevrolet
...or better yet, this one which is CNC'd from GM Performance:
http://www.gmpartsdirect.com/results...umber=12363420
Either the above will fit under a cowl hood and the stock-type cowl hood air cleaner.
Good luck,
Wes
Straight-line-69 is offline
post #4 of 5 (permalink) Old Oct 27th, 14, 09:41 PM Thread Starter
Cory
yeah im going use the oval port heads thats why i asked about the hieght... i think the edebrock rpm looks fairly close to the rect port intake as long as it isnt too high for the cowl air cleaner i want to get.
post #5 of 5 (permalink) Old Oct 28th, 14, 05:05 AM
Plenty of guys running the 163 rectangle port manifold with their oval port heads over on Team Chevelle. Concesus is it works fine. http://www.chevelles.com/forums/show...old+oval+heads
buenymayor is offline
