What do you think this combo would make? - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 27th, 14, 08:16 PM Thread Starter
Arch Stanton's Avatar
496 big block
10:1 comp
850 holley
Weiand Stealth
781 heads with 2.19 and 1.88 valves, bowls blended, garage porting job
.590 lift cam with 242 at .050
Must fit under stock flat hood.
Any ideas on what it might crank out?
- John
Misfit tortured soul. Lone wolf. Unicorn.
'67 V8 Camaro - 12637, 797-Z (Parchment), M-M (Royal Plum), 2M, 3K, 5Y
Arch Stanton is offline
post #2 of 7 (permalink) Old Oct 28th, 14, 09:31 AM
Anne
Re: What do you think this combo would make?
Originally Posted by Arch Stanton View Post
496 big block
10:1 comp
850 holley
Weiand Stealth
525 if a flat tappet cam ; 550 if a roller
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #3 of 7 (permalink) Old Oct 28th, 14, 09:46 AM Thread Starter
Think there'd be any difference if I use a Eddy Performer RPM? I could use either one....doesn't exactly matter.
- John
post #4 of 7 (permalink) Old Oct 28th, 14, 02:54 PM
Anne
About the same. Here's a good thread :
http://www.chevelles.com/forums/showthread.php?t=270812
Ronald Reagan
post #5 of 7 (permalink) Old Oct 28th, 14, 03:51 PM
I have a 496 Stroker in My camaro SS with that Combination EXCEPT the static ratio is 9.75 , and it has a roller cam It made 585 ft lbs of tourqe on the Dyno and 565 With an EDLEBROCK Dual Plane performer RPM manifold. 850 DP holley on 100 Octane. I lost 30 HP when I switced to the Dual plane manifold But I wanted to use the Stock hood.
Big Block Tom is offline
post #6 of 7 (permalink) Old Oct 28th, 14, 06:29 PM Thread Starter
That was good info!
- John
post #7 of 7 (permalink) Old Oct 29th, 14, 07:56 AM
Chris
OEM heads do not like single pattern cams. The exhaust ports need help and this comes from more duration on the exhaust lobe. I would feel it should make about 525 or so.
Chris
cstraub is offline
