need advice - new engine start/oil line question - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 2nd, 14, 09:23 AM Thread Starter
I have a brand new engine installed. It has been started and dyno tested by the builder. After I installed the new engine, I connected the console oil gauge line to the block.
The interior of the car has nothing in it. I'd like to fire up the engine without installing the console. Doing so right now would probably dump the entire contents of the engine inside the car.
Any ideas on what to do without installing the console?
68_RS is offline
post #2 of 10 (permalink) Old Nov 2nd, 14, 09:27 AM
kevin
Re: need advice - new engine start/oil line question
go to your parts store and buy a mechanical gauge
flat tire is online now
post #3 of 10 (permalink) Old Nov 2nd, 14, 09:34 AM
Steiner
I'd do the gauge like mentioned and remove what you already put in using all the parts supplied with the cheapie kit instead of risking messing up a piece from the console line kit. If you don't care about watching the pressure just grab a 1/8 NPT pipe plug for a few pennies at Ace, Home Depot, etc., remove the console line adapter, and put the plug in. I reckon ghetto move would be pulling the oil dipstick out and ziptie-ing the oil line in the dipstick hole. Wouldn't try it myself but wouldn't mind watching someone else do it.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 10 (permalink) Old Nov 2nd, 14, 09:44 AM
scblucam's Avatar
Dude, Really??
68 302 M20 - 85 IROC Z
scblucam is offline
post #5 of 10 (permalink) Old Nov 2nd, 14, 09:56 AM
Steiner, now that's creative, a little bit redneck perhaps but definitely creative!
NH69Z28RS is offline
post #6 of 10 (permalink) Old Nov 2nd, 14, 10:13 AM
Steiner
Originally Posted by scblucam View Post
Dude, Really??
'69 Camaro
500hp/538lbft
Steiner is offline
post #7 of 10 (permalink) Old Nov 2nd, 14, 10:40 AM
Install your dummy light oil pressure sender or cap it with the same threads then fire it up.
COPO is offline
post #8 of 10 (permalink) Old Nov 2nd, 14, 11:22 AM Thread Starter
I have the threaded plug that came with the engine. I can definitely reinstall that.
I think I would need a new oil line when putting it back in right? Wouldn't the ferrules get messed up?
68_RS is offline
post #9 of 10 (permalink) Old Nov 2nd, 14, 11:25 AM
Steiner
I've reused them a couple of times. Since the line's not connected can't you pull it back through the firewall and unscrew the fitting with the line still connected if you're concerned?
'69 Camaro
500hp/538lbft
Steiner is offline
post #10 of 10 (permalink) Old Nov 2nd, 14, 11:28 AM
No, I've had my gauges since the early 80's and they've been unscrewed many times, both oil pressure and vacuum gauges with the nylon tube lines.
COPO is offline
