383 Vacuum setup correct? - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 3rd, 14, 03:52 PM Thread Starter
CC
67 Camaro
383 SBC
Comp Cams 280H Cam
HEI ignition
TKO-600 5-speed trans.
Holley 650 DP carb
Edelbrock Intake
4 wheel disc power disk brakes (stock size booster).
Hey guys. I've been having some cooling issues with my 383, and after a ton of reading through the posts, one of the items on my list to check is the vacuum lines and how the vacuum advance is connected (ported VS manifold). I know manifold vacuum source generally is preferred. I was wondering if in general I have everything connected correctly. I've attached a generic Holley carb photo for reference that I found on the internet, (ignore the extra lines). the photo has the vacuum ports in the same location as my carb.
Currently, I have the following connections:
A: Connects to a Tee, one side goes to PCV valve in valve cover. Other side goes to brake booster. (4 wheel disc brakes, brakes have been working perfectly with nice assist)
B: This currently connects directly to HEI vacuum advance.
C: Has a plug on it.
Does this seem like a good/best setup? Thanks!
- Colby
67 Camaro, 383, TKO-600, 4 wheel disc brakes, black/black
CC is offline
post #2 of 2 (permalink) Old Nov 3rd, 14, 04:09 PM
Fred
Re: 383 Vacuum setup correct?
If it were mine,,,,,,,,,,,
I would loose the Tee. That location is correct for the PCV. But I would tap into the plenum (or a bung location) to provide brake boost.
128.79mph 1.428 60'
Fred Ficarra is offline
