Holley Power Valve - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 4th, 14, 06:04 AM Thread Starter
Bruce
Holley Power Valve
What power valve # should I use in a Holley 750 VA in a 454 bb mild cam 4 SPD, 3:42 gears.
The Camaro Guy is online now
post #2 of 4 (permalink) Old Nov 4th, 14, 07:48 AM
GM
Re: Holley Power Valve
I hope this video helps:
https://www.youtube.com/watch?v=mE_xTUXQJQ8
72 Nova 454 LS7 ATI Turbo 400 Moser WaveTrac rear
copter is offline
post #3 of 4 (permalink) Old Nov 4th, 14, 11:44 AM
Steps
That is part of dialling the carb and timing curves in as described in many older posts....
u need to know the engine vaccuum characteristics of the engine ONCE TUNED into the dialled in specs... idle and cruise vacuums...
Steptoe is offline
post #4 of 4 (permalink) Old Nov 4th, 14, 12:07 PM
Like Steps says once you have maximized the engine vacuum by tuning the idle circuit to obtain the highest vacuum, you cut it in half and round up. The power valve installed in the carb when Holley made it was an 8.5. Put that in there until you can prove to yourself that you really have to change it. This could be because of a cam problem or the carb being a little small for your motor's displacement creating vacuum problems.
Big Dave
Larger Dave is offline
