69 camaro base coupe 327/210ho need a timimng chain set recommendation - Team Camaro Tech
post #1 of 14 (permalink) Old Nov 4th, 14, 07:54 PM Thread Starter
bigsteve
Would like to know what is a good brand /part number for a replacement timing gear set for a 69 327 / 210 hp. Also how do I know if the bottom gear is 1 or 3 splines? My timing mark jumps around when I put a timing light on it?
bigsteve is offline
post #2 of 14 (permalink) Old Nov 4th, 14, 08:29 PM
Smile Re: 69 camaro base coupe 327/210ho need a timimng chain set recommenda
Just get a good american made set ! The stock crankshaft will only have one key (Spline) the 3 key (spline) timing gear is only to advance or retard the crank timing, usually by 4.
TJS69 is offline
post #3 of 14 (permalink) Old Nov 4th, 14, 08:36 PM Thread Starter
bigsteve
I looked on Rockauto and they listed about 25 timing chains for the car.
bigsteve is offline
post #4 of 14 (permalink) Old Nov 4th, 14, 08:38 PM Thread Starter
bigsteve
how about this?
Brand: Melling
Part Number: 3-499S
bigsteve is offline
post #5 of 14 (permalink) Old Nov 5th, 14, 09:12 AM
Anne
I would leave the lower sprocket alone.
Remove the chain and cam sprocket and take it to the auto parts store. Match it up and install the new chain.
I would never do this on a performance setup but you will be fine.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #6 of 14 (permalink) Old Nov 5th, 14, 12:12 PM
The Cloyes set on Rock Auto should be fine.
CLOYES Part # C3023SP - $18.39
TJS69 is offline
post #7 of 14 (permalink) Old Nov 5th, 14, 02:27 PM
Michael
X2 on the Cloyes.
mahunt is offline
post #8 of 14 (permalink) Old Nov 5th, 14, 05:46 PM Thread Starter
bigsteve
Isn't Cloyes part number C3023SP a double roller chain and if so will it fit in the OEM timing chain cover? Should I leave the lower sprocket alone?
bigsteve is offline
post #9 of 14 (permalink) Old Nov 5th, 14, 05:53 PM
Yes that sure looks like a double roller.
No, you will not be able to keep the lower sprocket. You will have to use a gear puller to remove it.
Yes it will fit under the stock OEM timing cover.
Melrose RS is offline
post #10 of 14 (permalink) Old Nov 5th, 14, 06:10 PM Thread Starter
bigsteve
what about this gasket kit with relocate crank seal? Not sure if Fel Pro kit has this.
VICTOR REINZ Part # JV779
Oil Pump Gasket Not Included; Sealant Not Included; Timing Cover Gasket Material: Paper; Contains Extended Case Lip Relocator Timing Cover Seal
bigsteve is offline
post #11 of 14 (permalink) Old Nov 6th, 14, 02:54 PM Thread Starter
bigsteve
Checked my timing chain today and it looks like I have about 10 degrees slop in it. I ordered the Cloyes time set and a Fel Pro timing chain cover gasket set. If there is anything else I need please let me know.
bigsteve is offline
post #12 of 14 (permalink) Old Nov 6th, 14, 05:27 PM Thread Starter
bigsteve
Do I need to drop the oil pan to remove the timing chain cover?
bigsteve is offline
post #13 of 14 (permalink) Old Nov 6th, 14, 06:44 PM
Fred
I hate the job you're having to do Steve. It's so tempting to say that it's about as easy to just pull the engine. At least that way you can dig into the rest of the parts. The fact that the chain is worn out sure would lead me to think the rest of it is ready for some R&R too.
128.79mph 1.428 60'
Fred Ficarra is offline
post #14 of 14 (permalink) Old Nov 6th, 14, 07:19 PM Thread Starter
bigsteve
when I turn the crank I feel about 5 to 6 degrees slop and then it gets tight and the distributor rotor starts turning around 9 to 10 degrees. What is the actual number of slop in the chain? The first 5-6 or second number 9-10?
bigsteve is offline
