Jet sizing: - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 6th, 14, 06:31 AM Thread Starter
Jet sizing:
Is there a way to find out which size jets (and metering rods) came with a particular engine and/or engine car combo:
For example 77 monte carlo with 400 small block.
83 c-10 with 305
76 nova with 250 inline six etc. etc. etc.
puff puff is offline
post #2 of 10 (permalink) Old Nov 6th, 14, 01:46 PM
Re: Jet sizing:
If you had carb list numbers...then yes. As it is just the make/model....maybe.
Just have to dig a little
68 Camaro~LSx ~all motor
post #3 of 10 (permalink) Old Nov 6th, 14, 03:09 PM
alex
Re: Jet sizing:
Exactly what Doug said if how ever you want to make any changes at all you have to drop three full jet sizes to notice any difference on a Holley. For example if the jet size is 74 you need to drop down to a 70 to start to make a difference . Alex
ss27 is offline
post #4 of 10 (permalink) Old Nov 7th, 14, 05:43 AM Thread Starter
Re: Jet sizing:
i guess the next natural question is, do you think, for example, a quadrajet for a 350 is jetted pretty much the same as for a 305?
i used a quad originally off of a 305 on a 350 for a while and it seemed just fine, but this was before i knew or cared about jetting. Now, i want to use that same carb on a 4.3 v-6, due to my recent engine "cooking" experience which i may or may not discuss in another thread.....
post #5 of 10 (permalink) Old Nov 7th, 14, 07:20 AM
alex
Re: Jet sizing:
Well puff I haven't used a quad in a long time but they are a great carb. It is my understanding that the factory had two versions as far as engines go . there was the small block version and the big block version.Thats why your 305carb ran good on the 350 . The thing with Q jets is it will flow only what the engine needs or calls for. I know that the small block version is capable of flowing 750 cfm the big block version is capable of flowing I believe 850cfm in its stock form and I could be off a tad off on that number. Of course they can be highly modified and there are several places that specialize in doing that . For the most part you can do some nice mods yourself but if it works good for what you have leave it alone. Alex
ss27 is offline
post #6 of 10 (permalink) Old Nov 7th, 14, 11:27 AM
Re: Jet sizing:
There are actually five different Rochester QuadraJet main body castings; and yes they do basically break down as to big block vs small block. There are three destined to be bolted on top of a big block engine with the Buick 455 having the highest cfm rated carb. They all differed by primary venture size. That coupled with the big blocks that have different parts that form the variable venture that is the secondaries.
You will probably want one of the smallest venture size for your six. Pontiac used one on their 4.3 liter overhead cam in-line six if you can find one.
Big Dave
Larger Dave is offline
post #7 of 10 (permalink) Old Nov 7th, 14, 12:15 PM
Steps
Re: Jet sizing:
A 2 jet size on a holley will make a significant difference 1 jet size also makes enough difference to be noticed if fine tuning.
A couple degrees of timing change at a given load/ rpm will make a significant difference
If one is ball park or 'bucket' tuning no u will not notice a single jet size change...
But should notice a 2 jet size.
and rem chance mixture change timing also....
A simple example of this is adjust a idle timing and the mixtures need adjusting and visa versa... it is the same right thru the rpm range
And how much one notices depends on experience and the tools used....O2 data and stop watch only way to go... bucket tuning/ dialling in went out last century
Steptoe is offline
post #8 of 10 (permalink) Old Nov 7th, 14, 01:51 PM
Re: Jet sizing:
May be a little fat... but being a vacuum secondary carb, you may be fine.
Will it run....Yes
Will it be exact.....No
Try it and see, then go from there.
post #9 of 10 (permalink) Old Nov 7th, 14, 08:21 PM Thread Starter
Re: Jet sizing:
Will it run....Yes
"fat" = rich?
post #10 of 10 (permalink) Old Nov 7th, 14, 10:38 PM
Vintage 68's Avatar
Wink Re: Jet sizing:
... i used a quad originally off of a 305 on a 350 for a while and it seemed just fine, but this was before i knew or cared about jetting. Now, i want to use that same carb on a 4.3 v-6, due to my recent engine "cooking" experience which i may or may not discuss in another thread.....
If you're talking Q-Jets ... then the size of the 'jet(s)' is often not as important as the size of the Rod
There were multiple combinations of a given jet (primaries are easily removed, secondary are often a fixed dia. 'washer' type stacked into body)with a selection of rod size to meet the requirements of a given engine combo.
I have listings of over 200 separate combinations depending on make/model/year/trans/application/etc. and personally have over 70+ just rods in my Q-Jet parts box for jets/rods.
The jets are marked with a numeric code for size and the rods are marked and designated by a Two-Alpha (AA, AB, AC ...) or numeric code from Rochester depending on their location.
Next thing to consider is the 'Hanger' pitch-length. A given 'hanger length' will position the rod further up or down in the jet hole and affect fuel flow at different times in the throttle application or Secondary plate opening cycle - leaning or richening mixture as needed at different power bands.
So you may be able to just substitute a larger rod dia. with the present jet to reduce fuel flow and meet your tuning needs.
Investigate what you have now and adjust as needed/wanted to meet your needs.
1968 Convertible
Some trucks
Vintage 68 is offline
