Valve spring compressor - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 7th, 14, 09:32 AM Thread Starter
Anne
I saw this Proform valve spring compressor and it looks very easy to use and is less than $50.
Does anyone know of a better/cheaper tool ?
I think I'm going to buy one unless someone knows of a better one !
https://www.youtube.com/watch?v=x9hOnbs9xwc
http://www.summitracing.com/parts/pro-66784/overview/
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #2 of 11 (permalink) Old Nov 7th, 14, 11:20 AM
Re: Valve spring compressor
I have it and it works very well just as shown. But if you are just going to be removing the spring to check it for being bad (not holding spring tension) use this one instead as it allows you to check the spring pressure on the head.
http://www.summitracing.com/parts/mo...Fc1Z7AodXRQAQg
I have that one as well as a Rimac bench top spring height vs pressure checker;
that I use to set up the heads and then just check pressure after that to keep from being surprised by a broken spring later. I also run dual to triple springs on all BBC heads as they tend to eat valve springs and having two extra springs helps to prevent sucking a valve (which is how I lost all but two motors while racing).
Big Dave
Larger Dave is offline
post #3 of 11 (permalink) Old Nov 7th, 14, 02:30 PM Thread Starter
Anne
Thanks Dave ! I believe I will order that compressor.
Ronald Reagan
post #4 of 11 (permalink) Old Nov 7th, 14, 03:34 PM
Pretty facncy. I just used one of these and it works well.
COPO is offline
post #5 of 11 (permalink) Old Nov 7th, 14, 04:29 PM Thread Starter
Anne
That looks like this one :
http://www.summitracing.com/parts/otc-4573/overview/
Is it very hard to rotate and tighten down ?
I'm thinking you only have to compress the spring about 1/4" to release the keepers.
Ronald Reagan
post #6 of 11 (permalink) Old Nov 7th, 14, 04:38 PM
Tom P's Avatar
I have the profrom compressor as well, very easy to use and easy to get the locks out. It made quick work of installing shims to get the installed heights correct.
67 new build alum. 406 | 69 RS/SS 496 631 HP / 618 TQ | 73 Z28 Survivor 36k miles | 89 IROC Z 2500 miles | 02 SS 35th Anniv. LE 645 miles |11 SS Berger 550HP (1 of 25) | 14 ZL1 6M Recaros
Tom P is offline
post #7 of 11 (permalink) Old Nov 7th, 14, 05:01 PM Thread Starter
Anne
Tom & Dave,
Some people commented that the fingers might need to be slightly bent to make even contact on the retainer.
Doesn't sound like a big deal. I have a BBC with 1.55" OD springs.
Did you have to bend yours or modify it to make it better ?
Ronald Reagan
post #8 of 11 (permalink) Old Nov 7th, 14, 07:49 PM
Tom P's Avatar
I did not have to modify anything - installed beehives with 1.186" diameter. You should be fine.
Tom P is offline
post #9 of 11 (permalink) Old Nov 9th, 14, 03:14 PM
Used this compressor to remove my triple spring on a bbc. Little tight but collapse enough to get keeper out.
TC # 349
zdld17 is offline
post #10 of 11 (permalink) Old Nov 9th, 14, 03:28 PM
69-Pace's Avatar
I was looking at this one also, but was worried last set on drivers side was the brake booster going to give me clearance issues.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #11 of 11 (permalink) Old Nov 14th, 14, 09:31 PM
Kev
I think I have one somewhere that's just made of U shaped piece of stamped steel that bolts to the rocker stud. You pull up and the spring compresses.
67sc is offline
