69 327 harmonic balancer installation without a center bolt - Team Camaro Tech
post #1 of 21 (permalink) Old Nov 7th, 14, 02:24 PM Thread Starter
bigsteve
69 327/210hp harmonic balancer installation on a crank that doesn't a center bolt.
bigsteve is offline
post #2 of 21 (permalink) Old Nov 7th, 14, 02:39 PM
Re: 69 327 harmonic balancer installation without a center bolt
You can driil and tap the crank, or use a block of wood and a hammer?
john68 is offline
post #3 of 21 (permalink) Old Nov 7th, 14, 04:33 PM
Steiner
Oven, some oil, and a prayer.
'69 Camaro
500hp/538lbft
Steiner is offline
post #4 of 21 (permalink) Old Nov 7th, 14, 04:54 PM
Anne
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #5 of 21 (permalink) Old Nov 7th, 14, 05:10 PM
The latter of these 2 options worked for me about 4 years ago and it's still hanging in there and I drive the car a lot.
bld22663 is offline
post #6 of 21 (permalink) Old Nov 7th, 14, 05:49 PM
ZZ_430's Avatar
Do yourself a favor and drill and tap it. I use an angle head drill if it's in the car. It's easy.
The hole is already started.
It doesn't have to be dead nuts straight.
(I can feel the flame posts already) LOL
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #7 of 21 (permalink) Old Nov 7th, 14, 07:07 PM
Anne
I agree totally.
Use a cobalt bit and take your time tapping the hole.
The last thing you need is to break the tap off in the hole.
Ronald Reagan
post #8 of 21 (permalink) Old Nov 10th, 14, 10:32 PM Thread Starter
bigsteve
I started taking the engine apart tonight to remove the timing chain and it turns out that my crank is already taped out with a 7/16 national fine threads. Will a harmonic balancer install tool work with a 7/16 NF bolt? Also it looks like the oil pan needs to be lowered to get the cover off?
bigsteve is offline
post #9 of 21 (permalink) Old Nov 11th, 14, 07:05 AM Thread Starter
bigsteve
The 327 cam gear is marked S-390 / date code I think is 2/82?
bigsteve is offline
post #10 of 21 (permalink) Old Nov 11th, 14, 07:29 AM
You can make an install tool with 7/16-20 all thread(grade 8 if you can find it), a couple of big washers and a lugnut.
Yes - the pan needs to be lowered
BPOS is offline
post #11 of 21 (permalink) Old Nov 11th, 14, 08:44 AM
Really, a hammer? Remind me not to have you work on my car. Don't hammer it on.
COPO is offline
post #12 of 21 (permalink) Old Nov 11th, 14, 12:35 PM Thread Starter
bigsteve
Thanks, I was able to barrow a installer at the local AutoZone. The timing gear cover had RTV on it , not sure if that is factory or not.
bigsteve is offline
post #13 of 21 (permalink) Old Nov 11th, 14, 12:41 PM
Sorry guess you did not read the service manual??
john68 is offline
post #14 of 21 (permalink) Old Nov 11th, 14, 12:48 PM
Miilions of early SBCs did not have threads in the crank's snout. Driving the balancer on with a hammer and a block of wood is just fine. Don't apply hammer blows to the outer edge of the balancer beyond the rubber ring - aim for the center.
Drill, tap and use an install tool if you can.
http://www.crankshaftcoalition.com/w...ve_and_install
BPOS is offline
post #15 of 21 (permalink) Old Nov 11th, 14, 04:36 PM Thread Starter
bigsteve
There was a 6 degree difference from the old timing chain to the new timing chain.
bigsteve is offline
