69 BB P/S Hose Heat Shield - Team Camaro Tech
post #1 of 1 (permalink) Old Mar 28th, 15, 11:26 AM Thread Starter
Timmy
Hi All
I had posted this to another Thread, I was asked by a member about my Heat Shield so I thought I would make it separate.
I have a 427 Big Block, IROC P/S Box and Doug's D-320 Headers, 2" Primary Tube .
I tried running what I thought was the most practical route being up along the Frame Rail inside of the Upper Control Arm mount, my Header Tubes were too close to the P/S Hoses.
My Hoses laid out perfect going down thru and around the Frame Motor Mounts, I have the Bracket at the front corner too. And that Black Corrugated sleeve that I positioned in the Bracket and added an Adel Clamp where the Brake line clamp Screw was.
I do have the AIM and it was not so clear, maybe with a Small Block there is a little more room.
If needed, I added a Heat Shield that I had made out of like .040" Stainless Steel, had a 1" flange bent at like 30 deg.
Removed my Frame Mount bolts and slid it under, marked the holes, Drilled it out and Installed it - Perfect.
1st Pic - Looking AFT
2nd Pic - Looking Straight Down
3rd Pic - Looking from the bottom up thru.
Timmy
Name:	1969 Camaro Power Steering Line Heat Shield 002.jpg
ID:	105841   Click image for larger version
Name:	1969 Camaro Power Steering Line Heat Shield 001.jpg
ID:	105849   Click image for larger version
Name:	1969 Camaro Power Steering Line Heat Shield 005.jpg
Name:	Power Steering pump Bolts 001.jpg
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
Last edited by french69ssrs; Mar 28th, 15 at 11:39 AM. Reason: Pictures did not load
french69ssrs is offline
