AFR 210 spark plugs - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 4th, 15, 01:42 PM Thread Starter
Marc
AFR 210 spark plugs
I just got the Dynatech headers (gorgeous and fit pretty darn good with the Steeroids) but I noticed that the #7 plug (Autolite 3910) will NO WAY fit. Can I just get a shorty plug (which one?) for that one cylinder, or would I have to do them all? Again, which would you recommend as the best short plug? It's a blown (6-71 with dual Demons) 377 small block. Thanks guys!
SS69Cam is offline
post #2 of 3 (permalink) Old Apr 4th, 15, 05:40 PM
the BOSS&Ralph
Re: AFR 210 spark plugs
I went through clearance issues with Hookers on AFR 195. IIRC a few "regular" spark plugs were just slightly longer than shorty plugs. Some NGK and Champions were good options. I was unhappy with all of the plugs so some heat and beat occurred on my headers.
friendlyviper is offline
post #3 of 3 (permalink) Old Apr 4th, 15, 07:28 PM
I have AFR 210 angle plug heads with Dynatech large stepped 1-3/4" to 1-7/8" primary tubes on my 406 and the Autolite 3910 plugs all fit fine. I do have 90 degree boots on the spark plug wires.
NH69Z28RS is offline
