Blown headgasket??? - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 5th, 15, 08:01 AM Thread Starter
Gary
Unhappy Blown headgasket???
How do I tell if I blew a head gasket or just an intake gasket?
There is coolant in the oilpan and white smoke out the exhaust and steam coming out the oil breather. It seems to run fine and idle ok. I'm confused and think a new head gasket, proper bolt installation, and intake gasket may solve the problem or do I just need a new intake gasket? It is a 1968 L78 396/375 iron head motor.
garyss396 is offline
post #2 of 10 (permalink) Old Apr 5th, 15, 09:41 AM
Jeff
yellow69RS's Avatar
Re: Blown headgasket???
IMHO it's highly unlikely that coolant is being sucked into the combustion chamber thru a bad intake gasket. Pull all the plugs and when you fine one that is completely white that is your bad cylinder. Do a cylinder leakage test on it with the radiator and oil caps off. I think you will find air pressure coming out the radiator cap.
Jeff
yellow69RS is offline
post #3 of 10 (permalink) Old Apr 5th, 15, 10:50 AM
Mickey
Moonpie's Avatar
To get to the head gasket you have to remove the manifold and expose the intake gaskets so.....I would recommend that first.
Moonpie is offline
post #4 of 10 (permalink) Old Apr 5th, 15, 10:54 AM
jared
Anti freeze is really bad for all your bearings. I'd get it figured out asap. You'll have to pull the intake any way. Start there.
jcfcamaro is offline
post #5 of 10 (permalink) Old Apr 5th, 15, 11:25 AM
alex
While your doing the job drain the oil and remove filter leave the plug out and let it drain to nothing. Anti freeze is a bearing killer get some butyl celosolve and put in with the fresh oil and filter. Run it a while and drain completely well then fresh oil and filter change again at 500 mi. Butyl celosolve is a glycol ether and will get rid of the antifreeze . Make sure you are very careful with it it is highly carcinogenous and is absorbed quickly through the skin, long gloves and a face shield . Alex
ss27 is offline
post #6 of 10 (permalink) Old Apr 5th, 15, 08:32 PM
Matt
Coolant in the oilpan? Coolant out the tailpipe? Could be more than a gasket. Hope it isn't a head or a block issue.
Matt69SS is offline
post #7 of 10 (permalink) Old Apr 5th, 15, 10:14 PM
ken
that could be a blown head gasket if it is blown in just the rite spot. But is sounds more like a crack in the head between a water jacket and a valve I would pull both heads and have them both checked no sense in playing around I can Guarantee you it is not a simple fix.
pasthelp is offline
post #8 of 10 (permalink) Old Apr 6th, 15, 11:54 AM
Have the heads mag'd and pressure tested. You could have a pinhole in the valve area or just a weak casting that has worn from all the years of coolant running though it. When you reassemble it, just fill the coolant with plain water for your initial drive test. Then you can drain the rad and then open the 2 block coolant bolts and empty it all then refill with a 50/50 mix.
COPO is offline
post #9 of 10 (permalink) Old Apr 6th, 15, 12:19 PM Thread Starter
Gary
Cool Re: Blown headgasket???
Thanks for the information guys. I'll pull both heads and have them checked. Not sure what is going on so I'll just hope it is not too bad.
post #10 of 10 (permalink) Old Apr 6th, 15, 01:29 PM
Fred
Gary, I've never blown a head gasket on a BBC (L78 included) but that is a substantial engine that deserves proper inspection and repair. I suggest that you buy, borrow or rent two tools: a shop crane and engine stand. Pull your engine and be prepared for a proper repair, that may well involve machine work.
128.79mph 1.428 60'
Fred Ficarra is offline
