Removing factory manifolds / rusted on - Team Camaro Tech
post #1 of 19 (permalink) Old Apr 5th, 15, 03:12 PM Thread Starter
Marc
My car still has the original motor that has never been pulled and the factory manifolds are still in place. The problem is that everything is rusted shut and I still have to remove some exhaust pieces to get the job done.
What should I use to prep this DIY project? PB Blaster? MAPP torch?
That's about all I have that I have access to in my garage.
PMD1969 is offline
post #2 of 19 (permalink) Old Apr 5th, 15, 05:11 PM
Alex
Re: Removing factory manifolds / rusted on
I use a lot of pb blaster on mine I am amazed at how easy the bolts come out.
1969 RS Camaro
1972 K5 Blazer
2010 Dodge Ram 2500 4X4
1969RSCAMARO is offline
post #3 of 19 (permalink) Old Apr 5th, 15, 05:32 PM
PB Blaster or Kroil is all I use anymore
Heat the blots up as hot as you can and soak with either of the above....maybe even doing is a few times (every day for a week depending on how bad the rust is)
ALSO be aware.... both are flammable !!!
68 Camaro~LSx ~all motor
post #4 of 19 (permalink) Old Apr 5th, 15, 09:13 PM Thread Starter
Marc
PB is a little cheaper and easier to find than Kroil, at least in my area. I have heard that PB Blaster is just ATF thinned down some but I no way of knowing if that is a fact.
Should I run the engine to get it hot and then soak the bolts or do it cold? How long should I let it sit before hitting it with an electric impact gun?
My major concern is snapping bolts in half and getting stuck in the block.
PMD1969 is offline
post #5 of 19 (permalink) Old Apr 5th, 15, 09:53 PM
Roger
rogerh's Avatar
When I removed my exhaust manifolds from the heads I used Liquid Wrench 24 hours before I removed them. They came off with no problem. Removing the exhaust from the exhaust system was another story. I used a sawsall to cut the pipes close to the flanges because I knew I was replacing the exhaust system. Got the manifolds out and used both liquid wrench and heat and still broke the studs in the flanges.
I was really surprised the factory didn't put gaskets between the heads and the manifolds.
I don't have one but I wouldn't use a impact wrench on a 3/8" or smaller bolt that I was worried about breaking. You loose any feeling with a impact.
Roger
rogerh is offline
post #6 of 19 (permalink) Old Apr 6th, 15, 06:11 AM
DT
Donny
DT's Avatar
I would NOT use an impact gun on the manifolds. A sure way to break a stud in the head !!!! PB Blaster worked very well for me. Soak overnight.
DT is offline
post #7 of 19 (permalink) Old Apr 6th, 15, 01:58 PM
Going by smell alone....PB is NOT ATF
post #8 of 19 (permalink) Old Apr 6th, 15, 02:14 PM
George
Gbauer's Avatar
Roger
Off topic but I bought a cheap Harbor Freight electric impact and it works pretty well for most things. Anything more powerful and I'd worry about breaking bolts/studs.
http://www.harborfreight.com/12-in-h...nch-68099.html
$50 isn't too bad and it comes in handy.
NO IMPACT WRENCHES ON EXHAUST MANIFOLDS. Just wanted to make that clear...
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #9 of 19 (permalink) Old Apr 7th, 15, 08:05 AM Thread Starter
Marc
Yeah the electric impact wrench I have is a cheapie but it works great for what I need it for. MY application is a little different so I am not sure what size the bolts are and I will have to ask. Mine is a Pontiac OHC motor and the manifolds are bolted together and then bolted to the head. The Main bolts that hold everything to the heads are pretty big so they might take the impact wrench. I am not sure a socket/extension/wrench will fit to get them out but I'll try it.
Here's a pic of what I am working on:
PMD1969 is offline
post #10 of 19 (permalink) Old Apr 7th, 15, 10:01 AM
Remove manifolds together, one piece.
Should be five bolts and a stud on each end securing them to the head.
9/16 inch socket/wrench.
Also with the exhaust studs/nuts, spray them down and spray the stud thread, and unscrew the nut to where it stops - don't force it.
Screw back onto the stud and flood with rust preventative or an oil and unscrew again.
Repeat as necessary in preventing stud breakage, maybe.
Upon assembly, use brass nuts.
post #11 of 19 (permalink) Old Apr 7th, 15, 12:57 PM
Darren
Big hot hammer!!!
chevysrule454 is offline
post #12 of 19 (permalink) Old Apr 7th, 15, 02:52 PM Thread Starter
Marc
Thanks for the tips. Have you owned a OHC before? The manifolds are attached with three bolts at the bottom and it would be very difficult to separate them on the car. My biggest problem is going to be the exhaust. The ultra rare "Y" pipe is something I am going to try and save but I know it will be very difficult. The bolts can be sacrificed but nothing else as they are irreplaceable.
PMD1969 is offline
post #13 of 19 (permalink) Old Apr 7th, 15, 06:16 PM
Read something on a forum somewhere and maybe on YouTube that a 50/50 mix of ATF and Actone was the best for loosening rusty bolts and nuts.
69z28302 is offline
post #14 of 19 (permalink) Old Apr 7th, 15, 06:26 PM
George
Gbauer's Avatar
I'm pretty familiar with that style engine...
Head over to www.inliners.org. Great site for inline 6 engines.
Mine: Offy intake, Langdon headers, 2.5" single exhaust to a Flowmaster 44, Holley 8007 390 CFM carb, HEI distributor, and electric fan conversion.
...and still DON'T USE AN IMPACT WRENCH ON YOUR MANIFOLD BRIDGE STUDS AND BOLTS.
(had to modify that a bit for you...)
To get it off you have bridges studs and nuts. The bridges are between the intake and exhaust manifold. There's a single stud between and a bridge. You might not be able to get a ratchet wrench in there. I believe the nuts are all 9/16". There are no nuts/studs on the ends. Only between the manifolds.
Step 1) Soak the heck out of it for a week in PB.
Step 2) Remove carb.
Step 3) Unbolt exhaust from exhaust manifold
Step 4) Remove power steering and bracket.
Step 5) Remove all vacuum lines.
Step 6) Break studs/nuts loose with box end of wrench.
Be sure to have a really good gasket on hand. Also I recommend copper RTV. Sealing the manifolds to the head is a PITA. I wouldn't take the intake apart from the exhaust unless you have a darn good reason to do so. I believe there are three bolts to do it. Two are visible. One is hidden away under a heat shield on the exhaust manifold (if you still have yours).
edit: Why are you removing them? I might have other fixes for you if I know a bit more.
If you want more power there are several options. Inliners really is the best way to find out about what's possible.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #15 of 19 (permalink) Old Apr 8th, 15, 05:13 PM Thread Starter
Marc
Holy huge photo's !!! I am guessing that it is a Chevy inline six?
PMD1969 is offline
