Intake/Carb height? - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 9th, 15, 02:20 PM Thread Starter
Tony
Intake/Carb height?
I have a stock Rochester intake and quadrajet. On a previous thread a lot of people convinced me to stick with the qjet. I would, however, like to switch the intake out. I have the original stock air cleaner. The black one with a chrome top and 350/300 sticker.
If I switch to the Edelbrock eps or rpm spread bore intake will I still be able to use my air cleaner under the stock ss hood? I really like the look of the old air cleaner so I hope it will fit.
1969 Camaro SS350, original motor/12 bolt/interior and build sheet in Fathom Green.
TClovis is offline
post #2 of 3 (permalink) Old Apr 9th, 15, 02:36 PM
Re: Intake/Carb height?
I think so. I have run my similar 275hp original air cleaner with the QJ and a 1" spacer on an Edelbrock performer with no trouble. I have the original flat hood.
To determine how much room you have to work with pile a handfull of play-doh on top of the air cleaner and close the hood.
Melrose RS is offline
post #3 of 3 (permalink) Old Apr 9th, 15, 07:31 PM Thread Starter
Tony
Are the Edelbrock eps and stock intake same height? I'll try the play dough trick.
TClovis is offline
