Is there an advantage with performer vs eps? - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 9th, 15, 10:16 PM Thread Starter
Tony
I want to pick up one of these if rpm won't fit. I read that eps was designed for edelbrock carbs but will it work well with any? Is there an advantage over Performer?
1969 Camaro SS350, original motor/12 bolt/interior and build sheet in Fathom Green.
TClovis is offline
post #2 of 5 (permalink) Old Apr 10th, 15, 12:02 AM
Smile Re: Is there an advantage with performer vs eps?
I don't believe a quadrajet will bolt on the EPS. It will on a performer.
TJS69 is online now
post #3 of 5 (permalink) Old Apr 10th, 15, 10:04 AM
George
It sits a bit higher than performer and, as stated, is for square bore only. Its supposed to have a bit more peak hp and torque also. Its still is rated from idle to 5500 so it will still "feel" like a performer for the most part.
carbuff67rs is offline
post #4 of 5 (permalink) Old Apr 10th, 15, 08:57 PM Thread Starter
Tony
If I have to lose my air cleaner I'm tempted to just do the rpm model so there is a performance difference. IS there a significant difference between stock and a performer or just weight?
TClovis is offline
post #5 of 5 (permalink) Old Apr 10th, 15, 09:40 PM
The performer is better at low RPM. The RPM is better at high RPM's.
TJS69 is online now
