Trouble shifting from 1st to 2nd - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 12th, 15, 05:21 AM Thread Starter
Dean
islanddean's Avatar
Not sure if this is an engine or transmission question so I'll start here. My engine is a 327 and transmission is a TH350 and both seem to be operating fine under normal conditions but there is one slight problem. If I'm sitting at a stop light, the light turns green, then I stand on the accelerator the cars takes off nicely. The problem is it wont shift in to second unless I back off the throttle quite a bit. Once it's in second it's off to the races and shifting from 2nd to 3rd is no problem. Hoping someone can explain this to me.
1967 Camaro Convertible with a 327, TH350transmission, Edelbrock 1406 600cfm carb, Edelbrock 1721 fuel pump & 2701 intake.
"The true measure of a man is not where he stands in time of comfort and convenience but where he stands in time of challenge and controversy."
MLK
islanddean is offline
post #2 of 5 (permalink) Old Apr 12th, 15, 05:42 AM
DT
Donny
DT's Avatar
Re: Trouble shifting from 1st to 2nd
How many miles on trans ?? You check the fluid ??? Maybe the vacuum modulator on side of transmission needs adjustment.
DT is offline
post #3 of 5 (permalink) Old Apr 12th, 15, 07:16 AM
Bill
x2 on the vacuum modulator. Its a cheap part and easy to replace.
arocars is offline
post #4 of 5 (permalink) Old Apr 12th, 15, 08:04 AM Thread Starter
Dean
islanddean's Avatar
I see that there are two different types of vacuum modulators for the TH350. One has a red stripe and there's one with a black stripe. Also...some say they are adjustable. Whats the difference in the stripe colors?
MLK
post #5 of 5 (permalink) Old Apr 12th, 15, 10:02 AM
Before you run out and change the modulator, check the vacuum line first.
Could be as simple as a hose connection.
BrewHog55 is offline
