Will qjet work on Performer EPS? - Team Camaro Tech
post #1 of 17 (permalink) Old Apr 12th, 15, 01:58 PM Thread Starter
Tony
After days of chewing on rebuilt qjet or buying new I decided to ship my qjet off to Lars (as recommended). This allows me to keep my original air cleaner, etc.
I'm considering replacing stock intake with a spread bore aluminum unit for a bit better performance. Which intake would work well with qjet and stock motor with headers...Performer, EPS or Weiand? I figure my engine compartment will still look mostly original with this minor upgrade.
1969 Camaro SS350, original motor/12 bolt/interior and build sheet in Fathom Green.
TClovis is offline
post #2 of 17 (permalink) Old Apr 12th, 15, 02:47 PM
Smile Re: Will qjet work on Performer EPS?
Straight performer - yes
performer eps - no
performer RPM - no
performer RPM Q-Jet - Yes
The only Weiand I could find for a q-jet was the Weiand Street Warrior intake manifold.
I would go with the Edelbrock Performer. http://www.summitracing.com/parts/edl-2101/overview/
Paint it the color of the block, which should be orange, and no one will know.
TJS69 is offline
post #3 of 17 (permalink) Old Apr 12th, 15, 03:15 PM Thread Starter
Tony
Great idea! Does the orange paint hold up on aluminum?
TClovis is offline
post #4 of 17 (permalink) Old Apr 12th, 15, 04:01 PM
I personally have not done it, but I know that there is a can of etching primer type stuff for aluminum.
TJS69 is offline
post #5 of 17 (permalink) Old Apr 12th, 15, 04:15 PM
DT
Donny
DT's Avatar
I painted my Edelbrock heads Chevy orange. They came out great.
DT is offline
post #6 of 17 (permalink) Old Apr 12th, 15, 10:43 PM Thread Starter
Tony
They look good! I'll have to see about it.
TClovis is offline
post #7 of 17 (permalink) Old Apr 13th, 15, 01:16 AM
Joe
Weiand action plus is an excellent intake with a Q-jet design. Unfortunately, they are no longer being produced new, but plenty of them are on ebay used. Part #8004
Here's a nice one I recently sold on ebay for $80.
The important thing here is that you ask me what kind of car I've got. "I've got a BITCHIN' CAMARO"
'68 350 4 speed
kookykrispy is offline
post #8 of 17 (permalink) Old Apr 16th, 15, 10:29 PM
Mike Petrovich
That's what I ended up doing , and it has worked fine for the past few years.
1968 327 sport coupe. Son of original owner.
mike p is offline
post #9 of 17 (permalink) Old Apr 17th, 15, 11:33 AM
George
Another thing to complicate matters is making sure to get an intake that Will work with your choke setup. If youve got the coil on the intake with the rod then you have to make sure the intake has a provision for such a setup. Sometimes the pad is there but the hole needs to be drilled and tapped for a screw. Being a 69 I guess you dont need to worry about an oil filler tube or accessory bolt hole as your alternator is on the other side.
carbuff67rs is offline
post #10 of 17 (permalink) Old Apr 17th, 15, 02:41 PM
Doug
I would check out Ebay for the Street Warrior 8004. They have plenty of them to choose from. If not interested in the Street Warrior check out the Performer RPM it has the dual pattern for the Q-jet and the Holley. The Performer intake manifold is just like a stock manifold but made from Aluminum. http://www.summitracing.com/parts/ed...make/chevrolet
Cdminter55 is offline
post #11 of 17 (permalink) Old Apr 17th, 15, 03:35 PM
If you do not block off the exhaust passages that heats the choke thermostat coil, the paint will burn off. But doing so will not allow the choke to open fully. The heat riser in the stock exhaust manifolds needs to be wired open with this configuration. If originality is not a concern, it's easier to convert to electric choke or just let the car warm up for a couple minutes. A local man here has a great rep for carb rebuilds.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #12 of 17 (permalink) Old Apr 17th, 15, 07:03 PM
jared
I used a EPS intake for the factory look. I also ground off the letters and put back the same texture
jcfcamaro is offline
post #13 of 17 (permalink) Old Apr 17th, 15, 07:08 PM
jared
More
post #14 of 17 (permalink) Old Apr 18th, 15, 08:06 PM
Looks nice!
I'm in the market for a new intake for my 327. Just curious, did you give any thought to the Performer Air Gap?
1969 Plain Jane Camaro - Restoration in progress...327, M20 wide, 12 bolt 3:31
My Camaro history here -->
RTCat is offline
post #15 of 17 (permalink) Old Apr 18th, 15, 08:22 PM Thread Starter
Tony
I am asking for opinions on another thread. I can't decide which way to go.
TClovis is offline
