Qjet Throttle linkage - Team Camaro Tech
post #1 of 12 (permalink) Old Apr 12th, 15, 11:04 PM Thread Starter
A
So I finally installed a 4 barrel carb onto my car. I bought a qjet which turns out was from an 80-85 chevy truck. So I think this carb is setup for a throttle cable but I currently do not have one. Without installing a throttle cable what is the best way to link up the throttle rod?
I tried using the lower hole pictured bellow but it binds at wot. I would like to connect my gas pedal rod to the stub thing I pointed out bellow.
1967 RS In Progress
327 with a 4 speed
XedLos is offline
post #2 of 12 (permalink) Old Apr 13th, 15, 12:46 AM
Joe
Re: Qjet Throttle linkage
I just dealt with this exact same issue today. Your picture looks almost identical to what I was looking at earlier this afternoon! I was scratching my head about how to deal with this, and came up with a solution. It may or may not be acceptable to you.
What I did: I used a cut-off wheel on my angle grinder and removed the 'stub thing' off the arm of the carb. I sliced it off, then put the carb sideways in my workbench vice and used a punch to drive the remainder of the stub out. The result is a hole, same size as the lower one. The hole is a little bit larger than the stud on the camaro's original linkage, so I then used a small hard rubber washer as a makeshift bushing to take up the small amount of slop. It is now installed and works well. If you want I can get you some pics later.
The important thing here is that you ask me what kind of car I've got. "I've got a BITCHIN' CAMARO"
'68 350 4 speed
kookykrispy is offline
post #3 of 12 (permalink) Old Apr 13th, 15, 07:23 AM Thread Starter
A
Thanks Joe! I get wgat you're saying and it's be cool to see some pictures.
Does anyone know what's the thread size of the throttle rod?
1967 RS In Progress
327 with a 4 speed
XedLos is offline
post #4 of 12 (permalink) Old Apr 13th, 15, 07:14 PM
Anne
Has to be 1/4 or 5/16 fine thread ?
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #5 of 12 (permalink) Old Apr 13th, 15, 08:40 PM
1/4-28 I think.
Melrose RS is offline
post #6 of 12 (permalink) Old Apr 14th, 15, 11:07 AM
Joe
Here ya go:
'68 350 4 speed
post #7 of 12 (permalink) Old Apr 14th, 15, 11:30 AM
Doug
You can purchase a new linkage rod from Summit Racing: http://www.summitracing.com/parts/aa...4170/overview/ or you can follow these instructions and make your own. https://www.camaros.net/forums/blog.php?b=153 The one you make looks better once completed. I used stainless steel brake line so it can be polished.
Cdminter55 is offline
post #8 of 12 (permalink) Old Apr 15th, 15, 10:58 AM Thread Starter
A
Originally Posted by kookykrispy View Post
Here ya go:
Thanks for the pictures.
What type of intake are you installing?
1967 RS In Progress
327 with a 4 speed
XedLos is offline
post #9 of 12 (permalink) Old Apr 16th, 15, 09:20 AM
Kevin
I have a question about this as well. The other day I was driving and then no pedal, luckily I was off the interstate and was near a parking lot. Some how the washer pulled out of the hole where it connects to the pedal part that comes through firewall. I just put a bigger washer then was good to go. My question relates to the accelerator pedal. It seem it lays pretty flat to the floor and doesn't seem to have a lot of room to push. If I take the other end of the rod and screw the little whatchamacallit, will that move my pedal out a little. I'm sure I've confused you. The "nut" thing on the rod itself looks like it can be turned and moved to different positions on the rod-talking about the cylinder shaped thing with the threaded hole. If I turn that in the direction closer to my carb, away from the firewall, will that give more pedal "room"?
Kev68ss is offline
post #10 of 12 (permalink) Old Apr 16th, 15, 10:04 AM
Joe
Its a Edelbrock performer #2101
I have the intake & valve covers loose because I'm in the middle of swapping in a new 268H cam
'68 350 4 speed
post #11 of 12 (permalink) Old Apr 16th, 15, 10:16 AM
Adjusting to shorten the rod between the carb and firewall joint will pull the pedal higher from the floor. Make sure you can get wide open throttle!
post #12 of 12 (permalink) Old Apr 16th, 15, 12:05 PM
Kevin
Cool-thanks!
Kev68ss is offline
