Headers - Team Camaro Tech
post #1 of 13 (permalink) Old Apr 13th, 15, 05:06 AM Thread Starter
Ken
Headers
I tried searching but not having much luck.
I have a 69 Camaro, SB 350 with a 200r4 trans, power steering, and factory A/C.
I currently have a set of Hooker super comp headers on however, the drivers side sits below the frame rail and the car is lower than stock. This side does drag occasionally. The collector at the end of the header has one of the bolt holes straight down, reducing clearance even more. After a couple years of use this bolt at the collector has been ground down a bit and bent up and at this point the gasket is leaking. The only way to undo this bolt is to cut it off and since the header flange is bent, I can not re-bolt it on anyway. I might be able to straighten the flange, but would end up with the same dragging issue anyway.
Anyway, what I want to find out who has a better fitting set of headers for my application. The Hookers fit well except the driver side hangs below the frame.
1969 SS/RS 350 Hugger Orange
kencar69 is offline
post #2 of 13 (permalink) Old Apr 13th, 15, 11:32 AM
Re: Headers
There will not be any better fitting headers if you are going to stick with long tube. This is because the headers are all made to fit a standard ride height car. You have customized your car and it will require either block hugger headers, a set of factory original two and a half inch outlet cast iron rams horn exhaust manifolds (that flow as well as any headers on the market up 'til 4,600 RPM), or a set of custom made long tube headers to fit your ride height.
I would cut off the prone to leaking three bolt exhaust flanges and instead weld on some V-band flanges, then use a V-band clamp to make it leak proof and a bit smaller in diameter. If you can weld I would also consider converting my off the shelf universal fit headers over to custom tubes by welding in pieces of J tubes to raise the collector up under the car and use oval tubing instead of round if you have bigger than stock pipes.
Larger Dave
Larger Dave is offline
post #3 of 13 (permalink) Old Apr 13th, 15, 02:10 PM
Larry
larryh56's Avatar
Re: Headers
If your application is a stockish 350 I would go with a set of Thorley Tri-ys if you want to change them. I had them on a 69 350 with a manual trans and p/s and they fit great and did not hang down. It did not have a/c so you should check on that first. Summit has them.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #4 of 13 (permalink) Old Apr 13th, 15, 02:11 PM
Doug
Re: Headers
Call Dynatech because you will have to give them all the info on your car. Engine size, AC, power steering, auto or standard trans, angle or straight plugs.
Cdminter55 is offline
post #5 of 13 (permalink) Old Apr 13th, 15, 04:45 PM
Smile Re: Headers
You can simply cut off the flange, install a reducer to your exhaust size, and install band clamps with the bolts to the side.
TJS69 is offline
post #6 of 13 (permalink) Old Apr 13th, 15, 06:55 PM
Robert
Re: Headers
If your headers are coated then my suggestion is not for you.
I was able to heat the driver side at the lower bends while applying pressure at the collector flange with a floor jack to bend the header upward. Afterwards I removed the header and repainted, it all worked out pretty well. This was on Hooker Comps not the Supers which I think are a bit heavier tubing.
Robert
TC member #18
rojo is offline
post #7 of 13 (permalink) Old Apr 13th, 15, 07:04 PM
Anne
Re: Headers
These headers fit great and are the ticket for a lowered Camaro :
http://www.summitracing.com/parts/bi...t/model/camaro
And the 1-1/2" primaries give plenty of plug clearance.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #8 of 13 (permalink) Old Apr 13th, 15, 07:54 PM
Todd
Hooked developed and released a new set of headers for your application last year that specifically address the fitment/compatibility characteristics you mention, especially the ground clearance. Send me a PM if you'd like more info or want to see fitment photos.
toddoky is offline
post #9 of 13 (permalink) Old Apr 14th, 15, 08:34 AM Thread Starter
Ken
Re: Headers
Hey thanks everyone, looks like I have a few choices to look at. TJS69 have you done this before? Looks like a pretty simple solution.
kencar69 is offline
post #10 of 13 (permalink) Old Apr 14th, 15, 09:35 AM
Mel
Re: Headers
I'll probably get a ration for this, but I replaced long tubes with flowtech mid length headers because I wanted to get as low as feasible for autocrossing and regular commuting. These things gave me gobs of usable torque I never had with the long tubes.
They were a hassle to install with a manual trans, but they really woke the car up and ground clearance is not an issue with 3" drop all around.
Blah blah blah 69 X55 blah blah.
notmybaby is offline
post #11 of 13 (permalink) Old Apr 14th, 15, 09:59 AM
Smile Re: Headers
I have not done this to mine. (probably should) I have 15 year old Hooker's that hang low. I know there have been people on this board that have done it.
You can always try it and if you don't like it, you were going to buy new headers anyway.
TJS69 is offline
post #12 of 13 (permalink) Old Apr 15th, 15, 04:17 AM Thread Starter
Ken
Re: Headers
Do you have a part number on those Flowtech mid length headers notmybaby? I'm not against using those at all. Good to have several options to consider.
kencar69 is offline
post #13 of 13 (permalink) Old Apr 15th, 15, 10:17 AM
Todd
Re: Headers
PM/info sent Kencar69
toddoky is offline
