air cleaner cold air base - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 13th, 15, 04:05 PM Thread Starter
James
Fitnessguy's Avatar
like this type of cold air intake base. haven't seen any on jegs or any places like that. any suggestions?
Fitnessguy is offline
post #2 of 6 (permalink) Old Apr 13th, 15, 07:08 PM
Anne
Re: air cleaner cold air base
How is that going to seal against the hood ?
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #3 of 6 (permalink) Old Apr 13th, 15, 07:24 PM
69-Pace's Avatar
I imagine the high intake thrusts the entire air cleaner into the hump of the aftermarket and I expect fiberglass cowl hood and the rubber gasket base shown seals against the hood. Looks clean but I have never seen it in the wild. Where did the picture come from?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 6 (permalink) Old Apr 14th, 15, 06:16 AM
Jeff
yellow69RS's Avatar
I wonder if that is a cake pan base. A google search will turn up several posts about them including some here on Team Camaro.
Jeff
yellow69RS is offline
post #5 of 6 (permalink) Old Apr 14th, 15, 07:19 AM
Gary
69Z28-RS's Avatar
The air cleaner base you picture seems to be almost flat, but other than that .. the air cleaner seems to function similarly to an L88 Corvette, where the air cleaner protrudes into the air duct in the elevated portion of the hood... ie.
http://www.bing.com/images/search?q=...271&ajaxhist=0
L88 air cleaner bases are available... you might check with the companies that sell those and see if they have a similar 'flat' base? and if they don't, it would seem fairly simple to make your own..
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #6 of 6 (permalink) Old Apr 14th, 15, 07:31 AM Thread Starter
James
Fitnessguy's Avatar
The picture came from a car for sale on RK motors out of Charlotte. If you haven't checked out their site before, you should. They have a lot of high dollar cars for sale. Good place to get ideas as each car has a ton of pics. I have seen this style base on several cars. The concept is the base seals against the hood and the air cleaner is up in the opening drawing in air through the cowl. I like it because it's clean looking and functional. Nothing too dramatic. Actually found one by spectre last night but they want too much for it. I could make my own no problem but wanted to see if there was something on the market that was good for the price.
