Holley vacumn advance location - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 14th, 15, 05:04 PM Thread Starter
jerry
JERRYS 69 Z's Avatar
Just put new Holley carb # 080457s---4160---600cfm elec choke on my
Near stock 350 engine. Should I connect vac line to ported vac fitting
as Holley recommends or to manifold vac fitting? Most info I read, says
To use manifold fitting. Does anyone have one of these carbs and
Which fitting are you using and why. Right now I have mine connected
To man vac. Runs very well. Thanks.
JERRYS 69 Z is offline
post #2 of 2 (permalink) Old Apr 14th, 15, 06:35 PM
Re: Holley vacumn advance location
A 69 Z28 would use full manifold vacuum. Smog motors use ported vacuum.
http://chevellestuff.net/tech/articl...r_manifold.htm
COPO is offline
