Carb recommendation for my needs - Team Camaro Tech
post #1 of 16 (permalink) Old Apr 18th, 15, 11:25 PM Thread Starter
Hi everyone,
I just picked up a 67 Camaro. It has a crate 350 with a mild cam and a 700R transmission. The current carb is a Holley 750cfm 4barrel double pumper with no choke.
I've been told this carb is too big for my motor and that a 650 cfm with vacuum secondary would suit it better.
My application is mainly street, so good torque and decent fuel economy is my goal (for now).
In the near future I'm considering building a 383 stroker. So I guess my question is, should I switch over to the recommended Holley 650 cfm with vacuum secondary and electric choke, and if I do, will this carb still work well with a 383 stroker?
All advice is appreciated! Thanks!
cozen89 is offline
post #2 of 16 (permalink) Old Apr 19th, 15, 08:21 AM
DT
Donny
DT's Avatar
Re: Carb recommendation for my needs
For a good street carb I would go with a Holley Street Avenger. I'm sure you will get several opinions on which carb to choose. http://www.summitracing.com/parts/hly-0-80670/overview/
DT is offline
post #3 of 16 (permalink) Old Apr 19th, 15, 09:11 AM
mike
I think the 750 can be tuned for the 350(pain in the butt) but would be easier to tune with the 383. The 650 will work easier for both but you may give up some hp(not much) with the 383. I guess it depends how radical you build the 383 also.
bigblockragtop is offline
post #4 of 16 (permalink) Old Apr 19th, 15, 09:25 AM
Tony
I am not one to answer questions on with little experience but I'm in a similar boat. I have a mild 350 and I'm putting on the Demon 650 vac sec since I read their cfm is underrated. It's advertised for mild 302-427 motors so I figure 350 is in the middle. Not the most technical logic I guess.
1969 Camaro SS350, original motor/12 bolt/interior and build sheet in Fathom Green.
TClovis is offline
post #5 of 16 (permalink) Old Apr 19th, 15, 11:04 AM
I agree...650VS carb would be better for your goals
68 Camaro~LSx ~all motor
post #6 of 16 (permalink) Old Apr 19th, 15, 11:18 AM
I tried a 650 sec/vac Holley on my 70 Z28 when it had a cr of 9:1 and it ran out of fuel/air at 5,000 rpm. I'd sell the 750 dp and get yourself a 750 with sec/vac.
COPO is offline
post #7 of 16 (permalink) Old Apr 19th, 15, 12:59 PM
Keith
The 3310 (750) vac secondary is a pretty versatile, all around carb--you can tune it to run well with your 350, and it will have enough CFM to run your 383 once you upgrade. Might be worth a look for you...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #8 of 16 (permalink) Old Apr 19th, 15, 03:41 PM
Originally Posted by keithl1967 View Post
the 3310 (750) vac secondary is a pretty versatile, all around carb--you can tune it to run well with your 350, and it will have enough cfm to run your 383 once you upgrade. Might be worth a look for you...
x2.
TC # 349
zdld17 is offline
post #9 of 16 (permalink) Old Apr 19th, 15, 07:58 PM Thread Starter
Thanks everyone for your responses. Seems there's quite a few different opinions on this. If and when I do go 383 I'm not going to go all out crazy on it. I still need it to run reliably and mainly for street use. Just looking for that extra "fun factor" when I want it if you know what I mean.
cozen89 is offline
post #10 of 16 (permalink) Old Apr 19th, 15, 08:34 PM
Anne
Go with a new design : the street demon 625 cfm is setup to work with your 700R4. Read the reviews from people who have bought it.
http://www.amazon.com/Demon-1901-Electric-Polymer-Carburetor/dp/B008EL4DC8
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #11 of 16 (permalink) Old Apr 21st, 15, 01:54 AM Thread Starter
Amazon.com: Demon 1901 625 CFM Electric Choke Polymer Street Demon Carburetor: Automotive
That carb looks interesting and has some great reviews. 2 local mechanics recommended I go with the Holley 650cfm vac secondary tho. Tried and true or new and cool? Hard to decide....
I don't really want to have to do this twice.
cozen89 is offline
post #12 of 16 (permalink) Old Apr 21st, 15, 03:06 AM
Anne
Here is a nice article on the street demon :
http://www.hotrod.com/how-to/engine/...fm-carburetor/
And a forum where people relay their experience with it :
http://www.hotrodders.com/forum/new-...rb-223299.html
Ronald Reagan
post #13 of 16 (permalink) Old Apr 21st, 15, 07:49 PM
Joe
cozen89,
I just put a Holley Street Demon 625 on my 350 HO and I love it! Starts great, easy to tune and has plenty of power. Also it is already setup of a 700r4 trans which shifts properly with this setup.
I would highly recommend this carb for the street.
-Joe
1969 Camaro V8 Base Model, Black w/White Rally Stripes, 350 HO w/ FiTech Go 4 600, HEI, 700r4 trans, 10 Bolt 4:10 Rear End, 15" Rally Wheels, 245/60/15 Rear, 235/60/15 Front
Non stop fun from 0 to 90 mph!
BadCo69 is offline
post #14 of 16 (permalink) Old Apr 22nd, 15, 01:10 PM Thread Starter
Originally Posted by BadCo69 View Post
cozen89,
-Joe
The feedback definitely sounds great for a 350, but I don't see much about this carb with a 383. This will be my only hesitation as it will definitely be stroked in the near future.
cozen89 is offline
post #15 of 16 (permalink) Old Apr 22nd, 15, 03:23 PM
Smile Re: Carb recommendation for my needs
A square bore 750 cfm, IMHO is too big on the street for a 350 ci engine. A 625 or 650 cfm is too small for a 383.
The street Demon is not a square bore carburetor, it is a spread bore carburetor, meaning the primaries are smaller than the secondaries.
I would run either a Quadrajet or the street Demon 750 cfm if you want to be able to use it on a 383 later on.
TJS69 is offline
